Starter issues
Old Dec 19, 2019 | 10:06 PM
71convertible's Avatar
71convertible
Default Starter issues
finally got the motor running with the body back on. Had to jump the solenoid with the key in the on position to start it. It shuts off with the key. I replaced the stater with a new one I had. Same problem won’t start with the key. It’s a 4 speed is there a neutral safety switch or something I’m missing? Or wrong switch?
Old Dec 19, 2019 | 10:37 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
Did you have this problem before you changed starters? Did you change the solenoid as well? How many wires and what location on the solenoid?
Hammerhead Fred's Avatar
Hammerhead Fred
Yes, there's a clutch safety switch.
Should find it just behind the clutch pedal.
Switch has purple wires and is activated via small rod from pedal to switch.
Old Dec 19, 2019 | 11:04 PM
71convertible
Thank you very much.
To Starter issues
