Headlight help request
Old Dec 28, 2019 | 03:56 PM
Baja64j's Avatar
Baja64j
Cruising
Default Headlight help request
We have a c3 (77e). Headlight actuators work only if I by-pass light switch and override system. Could the light switch be bad or what are your thoughts.
Old Dec 28, 2019 | 04:21 PM
'75's Avatar
'75
Yes, it's possible the vacuum valve part of the headlight switch is bad or broken, I've seen it a couple times. Have you double checked the connections to both those items?
Old Dec 29, 2019 | 11:17 AM
Devs77's Avatar
Devs77
Look in the C3 Tech/Performance area for the following:
Consolidated FAQ, Tech Tips and what happened to my sticky thread***
The third topic down is a good start on repairing the headlight vacuum system.
Good luck!
To Headlight help request
