Fiberoptics
Old Jan 16, 2020 | 07:11 PM
bakerstan's Avatar
bakerstan
2nd Gear
Default Fiberoptics
with a Fiberoptic harness how do you determine which line is which. The wires are wrapped in tape and not marked.
Old Jan 16, 2020 | 09:23 PM
jvp's Avatar
jvp
"Ask Tadge" Producer
This doesn't belong in "Ask Tadge". What year Corvette are you referring to? I assume a C3?
Old Jan 16, 2020 | 10:42 PM
bakerstan's Avatar
bakerstan
2nd Gear
A 1970 C3. If it doesn't belong to Ask Tadge where does it? This is my first time using CorvetteForum and it might be my last/
Old Jan 17, 2020 | 09:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What are you wanting to do? The front FO harness has six cables while the rear has three. The fronts should be in a connecter which mounts beneath the console.
Push come to shove, you can shine a light source through the cable one lamp at a time.
Old Jan 17, 2020 | 11:26 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
shine flashlight into fiber optic cable see which other end lights up.
Old Jan 17, 2020 | 07:14 PM
Stev-o's Avatar
Stev-o
Tadge is a senior GM engineer currently involved with the C8.
Since you have a C3, your question should be in the C3 tech section.
Wish I could help, I've had my C3 2 years and they have never worked, but I really dont mind.
To Fiberoptics
