Storing Create Engine (In Car)
Old Jan 19, 2020 | 08:04 PM
rodney25's Avatar
rodney25
Default Storing Create Engine (In Car)
Hi Team,
Here in my state it's very cold and I don't feel good driving a 75 convertible around town. Have a new BluePrint 350 create motor in the car with about 50mile on it. (Started the break-in process in the fall but it got to cold fast to continue.) Need to store the car for about 3-4 months. I always thought to start the engine once a week and let it warm up (running engine for about 20min) then turn off. This I thought would keep the oil and other fluids circulated and everything in the engine lubricated.
Was recently told not to do this because condensation would build up in the engine causing moisture and ultimately damage. If your not going to drive the car don't start it. Better to leave the engine un-started for up to 6-8 months and all will be just fine.
Any thoughts on this? Is this true?
Thanks.
Old Jan 19, 2020 | 08:28 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I personally don't think it matters.........on my own Vette....I put a Moroso carb cap over the carb and that's it......it matters more if your garage is cool and dry.
Jebby
Old Jan 19, 2020 | 09:19 PM
cv67's Avatar
cv67
St. Jude Donor '05
Start it 20 min is just fine.
Old Jan 19, 2020 | 09:35 PM
Stev-o's Avatar
Stev-o
My concern if leaving the car for 6-8 months would be gasoline. Dont know where you are located, but ethanol does bad things to your carb when sitting too long. I would start at least once/month and let it warm to operating temp [10min]
Old Jan 19, 2020 | 09:36 PM
forman's Avatar
forman
I start my car once a week pull it out in the driveway turn the heat on have a beer .. salt sucks
Old Jan 19, 2020 | 09:42 PM
jackson's Avatar
jackson
It's best to Not store with dirty oil. It's best to change O&F, run & check for leaks then put it away for winter. Using a filter with an Anti Drain Back Valve virtually eliminates any slow drain that may occur. Yea, I know; folks say "because filter is open-end-up that it needs no ADBV" ... well, do as you please ... ADBV cannot hurt.
It'll store for a long time without need to "keep the oil circulated" (especially w/ ADBV) and routinely running for short periods does only create acids in the oil but doesn't allow time to to get hot enough to boil moisture off.
You should remove battery and store it (warm better than cold) where you can put a trickle changer on it at least monthly.
Old Jan 20, 2020 | 11:48 AM
slammin's Avatar
slammin
[QUOTE=Stev-o;1600824799]My concern if leaving the car for 6-8 months would be gasoline. Dont know where you are located, but ethanol does bad things to your carb when sitting too long. /QUOTE]
I have a car that sits all winter. In the past the battery was my main concern. I had foot surgery almost 2 years. Complications kept me from driving the car for 20 months. It ran like crap until I got some Techtron thru it and fresh gas. Now when I put it to bed for the winter I fill it with corn-free regular.
Old Jan 20, 2020 | 12:12 PM
Tonio's Avatar
Tonio
Put a battery tender on it and don't worry. If you want to play it extra safe, cover the carb opening with a towel, and cover the exhaust pipe outlets with saran wrap or tennis *****. Keep the rodents and moisture out.
Old Jan 20, 2020 | 12:27 PM
OldCarBum's Avatar
OldCarBum
I believe in starting mine once a month and letting it warm up in the garage, shut it down and cover it back up.
But I live in Northern California and my garage never gets under 50 degrees.
When I lived in higher elevations where we got heavy snow and we owned boats, I would run the gas out in the fall, cover them up in the garage, place a 60 watt light fixture next to the engine block and turn the light on during a deep freeze and not worry.
Come spring, we pulled them out, and never had a problem.
Old Jan 20, 2020 | 10:01 PM
71 Vert LS1's Avatar
71 Vert LS1
I'm in balmy central MN. I always run corn free premium gas in my hot rods. I start mine up and let them run for 20-30 minutes so I know they come up to temp. Burns up any moisture in the oil. Also allows me to sit them and pretend its the middle of July!
Old Jan 21, 2020 | 07:40 AM
L88Plus's Avatar
L88Plus
Leave it alone. If it's not completely broken in, you won't be doing it any favors with a few short low rpm runs.
Old Jan 21, 2020 | 08:10 AM
The Punisher's Avatar
The Punisher
I think 20 mins should be good. Your car should easily be up to a good operating temp to burn off any moisture. I do this about 1 every 2 weeks and i pump my brakes to keep the calipers from leaking.
To Storing Create Engine (In Car)
