Washer tank
Old Jan 30, 2020 | 02:21 PM
Varveris Antonio's Avatar
Varveris Antonio
3rd Gear
Default Washer tank
replace the windshield washer tank ?C3 77
Old Jan 30, 2020 | 02:27 PM
KenSny's Avatar
KenSny
And your question is.....?
Old Jan 30, 2020 | 02:40 PM
adamdinat's Avatar
adamdinat
One of my projects is to replace the washer pump. It looks like a challenge to get to.
Old Jan 30, 2020 | 02:48 PM
L-46man's Avatar
L-46man
No! just put washer fluid in it! LOL.....Must be a millennial.
unkahal
Old Jan 30, 2020 | 02:49 PM
Varveris Antonio
3rd Gear
Hello.
Sorry I misspoke.
I would like to know how to remove the windshield washer tank because I think the engine has a problem.
Old Jan 30, 2020 | 02:59 PM
L-46man's Avatar
L-46man
Antonio...you're new...so
First tell us with as many words as you need what is wrong with the engine.....then we'll tell you how to fix it.....you're doing this backwards!
The brain trust here is VAST....trust us!
ps If the factory put it in, it can come out!
We don't charge by the word! lol
Unkahal (TioAldo)
Old Jan 30, 2020 | 03:09 PM
Varveris Antonio
3rd Gear
Unkahal (TioAldo)
Le moteur e fonctionne plus et je veux le remplacer .
Old Jan 30, 2020 | 04:37 PM
ukjohn's Avatar
ukjohn
Antonio, I'm guessing that you mean the washer pump isn't working and you want to replace that. Not sure if a 77 is the same but on my 78 there is 1 screw holding the filler neck and 2 screws holding the washer bottle (tank). The rear one of these 2 screws isn't all that easy to get to though, you might need to remove the splash shield at the bottom of the fender.
Old Jan 30, 2020 | 06:51 PM
revitup's Avatar
revitup
Removal of the tank/pump assy would require some additional engine disassembly but it's not required. The washer pump on a '77 can be replaced without removing the tank from its general position in the engine compartment. It just needs to be unbolted so it can be shifted around a little to enable pump replacement. All the bolts can be reached with a little patience. RockAuto has replacement pumps cheap.
Old Jan 30, 2020 | 10:12 PM
BKarol's Avatar
BKarol
I kept this in my favorites written by a forum member.
https://www.c3vr.com/vrforums/c3-gen...-to-do/487634/
Old Jan 31, 2020 | 09:33 AM
L-46man's Avatar
L-46man
I have found that an OFFSET RATCHETING screwdriver is VERY helpful!
good luck.
To Washer tank
