I have a 1972 L48 car with air conditioning. I am restoring the engine compartment and can find all the vacuum hoses reproduced except the 2 that come from the vapor canister behind the left front fender. There is one small one that goes from the small port on the canister up to the carb and a 3/8" hose that goes from the large port on the canister up to the T on the pcv valve then on to the baseplate of the carb. I cant seem to find those 2 anywhere! Anyone else found these from a vendor?
Thanks.
You could just take a section of each of the original hoses to a few local car parts stores (NAPA, CarQuest, Advance and, yes, even "The Zone") might have very similar hoses.
If you don't find something within 1 hour of starting your search..........order the 'good' stuff.
I'm trying to keep the car stock looking even down to the striping on the vacuum hoses. Haven't seen any white striped vacuum hoses at parts stores.
[QUOTE=7T1vette;1600993731]NCRS will appreciate your diligence and your $$$$. Hope all goes as you wish it!!
Not doing NCRS but keeping it close where I can.
If it's what I'm thinking, it's a thin wall hose and looks something like vacuum tubing, not your typical fuel line. Not easy to source. If that's what your hose looks like. How about a picture of the cross section?
