1979 L48 4 spd. Big camshaft and intake. Putting 2.5 inch dual exhaust and headers in soon.
right now I dont have a tach, I was wondering where ~5000 rpm is for each gear on the speedo. I like freeway onramp pulls and I’m not trying to break anything.
How could we guess that if we don't know what's in the engine. Cam for instance. Lots of variables.
I would start by getting a Tach, even it's a tach you have to mount to the steering column.
In each gear: shift when it feels like the engine is no longer pulling strong. You should not wind it "tight" in any range if you don't have an accurate tach to go by.
In 'high' gear, you can NEVER reach redline with a basically stock engine and rear gear.
Not true, depends on what rear is in the car.... With the 3:70 you may ..
4th gear at 5000 is ~130 mph for my 80. It has 3.08 rear gears, though.[/QUOTE]
holy cow my 4sp l82 is 3.7 rear..110 mph @5000....
so basically my max 5500 rpm is 121 mph..
it already sounds like its taking off to the moon on the highway..i guess if speed limit was 55..
WHy put a big cam in a low compression engine then limit your rpm? Just curious
Tachs are cheap
I bought the car in january and it already had the cam. Unfortunately the owner passed away and none of his service records were found, so I dont know the exact measurements. Its big though, every car guy I take for a drive immediately notices it.
I’m just being careful until I can take the engine apart and figure out exactly whats been done.
also its my daily driver.
Not quite. A 1979 L48 should have only come with the M20, standard 4-speed, with these ratios:
1st 2.64:1
2nd 1.75:1
3rd 1.34:1
4th 1.00:1
With a final drive of 3.08:1, as best I can tell.
So, with 27" wheels (255/60R15), 5000 RPM, I get:
1st 49 mph
2nd 75 mph
3rd 97 mph
4th 130 mph
What numbers were you using? Perhaps you had a typo?
In any case, you'd want to verify these numbers with a GPS speedometer and a calibrated tachometer. You can calculate the rear gear ratio with a helper. Put the car on jackstands, and a piece of tape on the driveshaft. Have the helper count the times the tape goes around while you turn a wheel exactly once around. On a 40 year-old car, I wouldn't trust anything without measuring it, including the stamp on the differential. If you cam can be changed, so can your rear gears.
1st 2.64:1
2nd 1.75:1
3rd 1.34:1
4th 1.00:1
1st 49 mph
2nd 75 mph
3rd 97 mph
4th 130 mph
What numbers were you using? Perhaps you had type?
