How does this underside look?
I've been looking around for my first 73 corvette and found one with the following pictures of the underside. What are your thoughts on the underside of this one? I am trying to avoid a rusty car or one with frame damage. Does anything jump out to you? I'm not looking for an original car or one in excellent condition, just a good condition run-and-driver.
Any help/comments would be much appreciated! Thank you
A badly rusted frame shows heavily rusted areas that a bubbled or have irregular raised surfaces on it. That frame (while rusty) still appears to be relatively smooth.
scattershiel, rusted headers and chrome aircleaner to me says driven pretty hard..
like others said check rust areas but looks fair
looks like a decent car., of course pull kick panels and inspect the windshield frame carefully.
my 69 had rust raining down. 68 looked good till i pulled window trim.
op asked for looks..opinions..
around here the frame will rust from the inside out as well because of humidity, mine is and will need to be replaced some day. If you can see big flakes inside the frame drain holes, I mean big flakes that wont fit through the holes then you may have something to look at but these pics you show are fine underneath. Lookk at the front body mounts in the footwells behind the kick panels. If those are bad theres a good chance your windshield frame is too. If you look at the edges of the windshield frame around the glass you can spot rust sometimes. As well as openning the doors and looking up into that area
How much work do you want to do to the car? Pulling the engine and transmission? Pulling the body off? What are your goals for the car? Knowing this ahead of time might make buying a nicer car less expensive in the long run.
Good luck with your decision and good that you got it up on the lift for pictures.
David Howard
AllVettes4Me
That frame is fine. Your rust is all on the surface and if the car is kept in a warm, dry environment, it wont worsen.
Someday you will likely have to do some work on the differential, spare tire tub or the leaf spring which requires removal of part of the exhaust pipes.
Also, Rear Spring bolt / cushion kit is in order. Otherwise, looks pretty good.
Yes, the windshield frame should be looked at if your goal is to preserve. It's like a U-channel where water can't drain out of. I suspect the top of the windshield surround on the ends is corroded worse than you'd think. Might even have some pinholes. Probably has pinholes. Pinholes allow water leak down inside the A-pillars which soon leads to major structural rust. GM used to spray an expanding foam inside the pillars to prevent wind blowing into the cabin (not sure on 73's). That foam traps the moisture and holds it there. Even my car from the LA area had fairly deep rust pits in the windshield frame (no holes fortunately). Not trying to scare you, just educate and give you the tools to look and hopefully interrupt any corrosion ahead of time.
My personal suggestion would be to remove the top stainless covers and look at it. Pay attention to the water sealing as you do so you can replicate upon install (use 3M non-hardening "Bedding Compound" [Amazon] to re-seal per OEM). If you find any pinholes on the outer edges of the top channel (about where the visors screw to), then you could either sandblast and cover the pinholes ...or remove the windshield and blast all around the frame (which probably also has pitting), re-do any metalwork, repaint, and put the windshield back in. The windshield can literally be removed in less than 15 minutes (5-min by a window guy) with a wire and 2-dowels, so not as big of a job as it sounds.
Or you could ignore the whole thing and just go on with life until it get to be an issue that can't be ignored.
[Edit] The intake air filter area is pretty small in terms of air filtering capability.
Good luck!
As a side note; it amazes me how people will put a 600-800 CFM carb on, then choke it off with a garden tractor air cleaner that flows 100-200 CFM?
