Stock radio install
Old Mar 28, 2020 | 08:58 PM
fastimes's Avatar
fastimes
St. Jude Donor '19-'20-'21-'22
Default Stock radio install
Will the factory radio fit through the console access panels, or is it necessary to remove the center cluster? The access openings look pretty tight.
The radio installation instructions in the service manual basically say to remove the whole front of the dash warning the the center cluster could collapse if forced.
Old Mar 28, 2020 | 09:25 PM
kansas123's Avatar
kansas123
I have put my radio ('72) in from the passenger side after removing the lower dash pad on that side and the access panel. It was indeed tight. I believe I also had to remove the screws of the center gauge cluster on the driver's side as well, so that I could lean the cluster in the direction of the rear of the vehicle to get as much room as possible to squeeze the radio in. Not sure if there was anything else back there I had to remove. Good luck....
Old Mar 28, 2020 | 10:01 PM
BarryB72's Avatar
BarryB72
I've done it like Kansas123 and I think I put a scratch across the front of the selector buttons. What I do now is take out the emergency brake console so I can slide the forward shift console (with gauge bezel attached) back as a unit. That does require removing the shift plate as well so maybe more 13 more screws and the hidden bolt in the back of the e brake console but it opens it up so much up front it's almost fun to change a radio.
Old Mar 28, 2020 | 10:43 PM
caskiguy's Avatar
caskiguy
May help explain a few things.
http://www.superchevy.com/how-to/car...tage-corvettes
Old Mar 29, 2020 | 12:05 AM
Eliredandblack's Avatar
Eliredandblack
I like to leave the two radio nuts loose until I get the gauge cluster and other adjacent modules lined up. With everything loose you don’t put any unnecessary stress on 40 plus year old parts.
Old Mar 29, 2020 | 09:04 AM
Wee's Avatar
Wee
Not sure if it will help much but here are some photos I took when installing an original radio in my 72.....The hardest part is putting it all back together and getting it to fit nicely. Mine turned out better than it was before I started. Each and every wire/vacuum hose has to be just right for everything to go back into place. The drivers side speaker is a pain to replace as well.
72 radio install....
Good Luck....
Brian
Old Mar 29, 2020 | 10:10 AM
napa68's Avatar
napa68
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
Thank you!
Old Mar 29, 2020 | 11:18 AM
fastimes's Avatar
fastimes
Thank you for the advice (and photos). It is very much appreciated.
I have all stock audio pieces restored/repaired and ready to go back in, I'm just scared *%$^ to do this job. My dash is in great shape. I just don't want to screw it up.
Being a dealer installed item, they must've knocked this job out in no time. Then again, the interior pieces weren't 48 years old at the time either.
Old Mar 29, 2020 | 04:20 PM
7T1vette's Avatar
7T1vette
Put blue painter's tape on the chrome pushbuttons and any other areas to prevent scratches during assembly. The blue taipe won't residue on the parts.
Old Mar 29, 2020 | 08:15 PM
kdf1986's Avatar
kdf1986
I like 7T1Vettes idea. I learned that most of the time I do this type of work the blue tape is added protection.
kdf
Old Mar 30, 2020 | 06:35 PM
blue427's Avatar
blue427
personally, I think they built the car around the radio.
Old Mar 30, 2020 | 08:14 PM
fastimes's Avatar
fastimes
Certainly seems that way!
To Stock radio install
