Number 4 Body Mount Question
That's the passenger side. The bushing looks to be smooooooshed, and the knuckle above it is barely recognizable. I'd like replace them both, both I'm not about to do a frame off right now. Eventually maybe, but I'd actually like to drive my vette this summer, so I'd prefer to wait.
The driver side isn't much better.
My goal is to replace the steel "knuckle"/body mount reinforcement and the bushing, linked below. My question is: Can it be done without lifting the whole body as this next post suggests?
https://cscreproductions.com/shop/by...reinforcement/
https://www.ecklerscorvette.com/corv...1968-1972.html
I found the following post on corvettec3.com and it got me to thinking. While I have the interior out, it'd be a heck of a lot easier to tackle this now if the meat of this post is true.
Here's the post from Eddie who suggests this can be done without completely separating the body from the frame.
This is for 68-72 Chrome Bumper Cars
1. start by placing the rear of the car on jack stands (rear wheels off the ground) and remove the spare tire carrier. You now have easy access to the rear bumper brackets. There are 2 in the center that go to the license plate area of the body, 2 that go to the innermost bumper mounts, and 2 that go to the outer bumper mounts. Disconnect the antenna grounding strap. Disconnect battery cable where it mounts to the frame. Loosen parking brake adjustment as much as it will go. The adjustment is in the transmission tunnel, before the cable splits off to the wheels. You do not have to completely disconnect the cable. Remove the top bolts from the shocks. If your rubber gas lines are run tightly from the tank to the steel frame lines, clamp them off with vice grips and disconnect them from the frame mounted steel lines. Make a check of anything that might connect the body to
the frame in the rear, that will not give a few inches. There is an access cover in the forward portion of the rear wheel well. Remove the four bolts holding it on. This exposes the #3 body mount bolt. Now the best way I've found to remove the #4 body mount bolt is to grind off the head and push it up and out, or cut it between the mount support & spacer. You
decide which way is best. You can try unscrewing it...but I fear it is futile! Do take note of how many shims are under the mount spacer also. You'll find the cage & nut for the #4 mount in a deep recess in the far corners of the rear interior. Might have to pull back carpet to find it.This is the hard part….you’ll have to loosen the #3 body mount bolt (front portion behind rear wheel well access cover) enough to get at least 2" of body travel off the frame. If it's badly rusted, soak the heck out of it. Don't disturb the #3 shims between the body & frame...no need to.
I made long T shaped lift (picture an upside down T) out of 2"x8" (cross portion of T) and 2"x12" (long portion of T) lumber, long enough to fit under the fiberglass rear storage area lip. (just in front of rear cross member) I placed a floor jack under this T and it held the body up enough to
be able to work on the #4. All you need is a few inches. If your sure everything is loose, and your ready to continue..lets.
With the car up on jack stands, and your temp T lift holding up the body under the rear storage compartment, loosen the #3 mount bolt, and grind off that #4 bolt head taking notice of how many shims are present. Punch or pull the #4 bolt through from the inside of the rear deck, in the rear deck
valley. Now give the floor jack a few pumps and watch if the body moves a bit off the frame. If not, that's OK...you'll only need a few inches to remove the #4 reinforcement. There is a cage nut & cage at the bottom of that valley. It might be in good condition...but I doubt it. Check it. If the cage
is good and the bolt is rusted, you'll have to remove the cage (which is riveted to the fiberglass). The #4 mount reinforcement is riveted to the fiberglass all the way around., so to remove it you'll have to drill out the rivets. By the pix I've recently seen you may have to do some fiberglass work to repair the valley before trying to attach the new reinforcement cup. Check other sources for fiberglass repair. It's pretty easy in this case, especially since your not doing body work or painting. Only want to stiffen up the body so the reinforcement has meat under it for strength. Attach the
new #4 reinforcement by either using pop rivets, or as I did, with #12 or #10 stainless steel screws , nylon lock nuts, and stainless washers. For those with destroyed cage & cage nuts, don't bother trying to re-attach the cage. It's near impossible without the body off. I used a large diameter
stainless washer on the inside to retain the stainless mount bolt. Some guys have made square pieces of metal with a bolt welded to it, that fits perfectly down in that valley and accepts the mount bolt. Now..the mount bolts that come with the kits are grade 5 steel. A good quality stainless
bolt is comparable to grade 5 steel. Since there is little to no stress on that bolt, I used stainless. Your call!!! Install the mount bolt, spacer, and shims. If all your shims were rusted away, you'll have a trial and error procedure trying to ad shims to even up the body . I took measurements
between the body & frame through out the rear kick up (just in front of #4 mount) until the measurements were even. Mine took 3 shims on one side and two on the other. Take these measurements with the mount bolt tightened with
spacer and shims in place, and the body lowered onto the frame. Well that's about all I can suggest.
Hope I remembered everything...Good Luck...
Eddie
Can this slight lift be done safely? Has anyone done it and what was the experience like? Troubleshooting? As always many thanks in advance.
I can't see just both #4 mounts being in that state would cause the whole body to lean over as you say.
That big crack in the driver side wheel well is not a good thing either.
I hope I'm wrong but you might need to investigate further before you attempt to fix anything.
https://www.corvetteforum.com/forums...oval-tool.html
Look down towards the end and you can see what I needed to do to get it in, (I can't even spell NCRS)
M
"The rubber body mounts found on 73-82 Corvettes vastly improved noise and ride over the solid aluminum mounts used on the 68-72 models. It is possible to retrofit the later rubber mounts on 68-72 and reap the benefits of a better ride, less road noise and less risk of fiberglass stress cracks. I recommend buying a body mount kit as it also comes with all new bolts, washers, nuts and shims."
Any thoughts on the substitution of the later parts?
Aside from needing some additional clearance to do the replacement, what other complications am I bound to run into? (I'm doing a restomod, so I could care less about it being an exact substitution.)
M
M
I'd like to improve the ride a bit, especially if it's easy.
I think I'll call our buddies at Willcoxx (if they're working from home, I suppose.) They'd know about dimension differences I'm sure. Thanks.
#3 I think the little cover plate at the front of the rear-wheel well will let you shoot in,
#2 you need to remove the kick panels and
#1 in through the side grills
M
