Beachmaster
Old Apr 16, 2020 | 04:55 PM
beachmaster's Avatar
beachmaster
Default Beachmaster
Due to a large cam and little manifold vacuum, I have installed an electric vacuum pump for the power brake booster. When it operates as soon as it shuts off, I hear what sounds like the vacuum collapsing back through the pump. It is an A/C Delco 20939309 original equipment power brake booster pump assembly. I am operating it with a vacuum control switch, which is supposed to shut off at 18-20" vacuum. I assumed it had an internal check valve, but it doesn't sound like it and I have no vacuum when it shuts off. please advise.
Old Apr 16, 2020 | 06:20 PM
MelWff's Avatar
MelWff
Did you check the booster check valve?
Old Apr 17, 2020 | 11:42 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Yes like Mel said, you should have a booster check valve and a check valve just before the pump. I just bought a new pump and it came with 2 tees and 2 check valves.
Old Apr 17, 2020 | 07:02 PM
beachmaster
I am putting my system together without buying kits, less costly, but more aggravation. I order a new check valve for the pump and had already installed one on the booster. I appreciate your help,
Mike
Old Apr 18, 2020 | 12:15 PM
MelWff's Avatar
MelWff
If you pull the check valve out of the booster immediately after stopping the engine and you do not hear a swoosh sound, either the check valve is bad or the booster diaphragm is bad.
Old Apr 18, 2020 | 06:11 PM
vettebuyer6369's Avatar
vettebuyer6369
Would you like your subject line/thread title changed from your name to something that would be related to the thread content? You might get more people interested in your question.
To Beachmaster
