Park not working
Old Apr 19, 2020 | 10:12 AM
Cdbarber's Avatar
Cdbarber
Default Park not working
76’ C3 still rolls when in park. I have replaced the calipers, but noticed the parking brake cable is broken. Is this why it still rolls when in park?
Old Apr 19, 2020 | 08:23 PM
bazza77's Avatar
bazza77
Putting an auto gearbox in park engages a pin to stop the internal gears rotating , as your tail shaft / differential and wheels are all attached to the gearbox then that stops the car rolling.
Handbrake is totally seperate to all that.
Old Apr 19, 2020 | 08:29 PM
jackson's Avatar
jackson
Default parking pawl
parking pawl
https://en.wikipedia.org/wiki/Parking_pawl
Old Apr 20, 2020 | 07:18 AM
derekderek's Avatar
derekderek
jack up back wheels. spin them. disconnect shifter linkage at trans. cycle it back and forth and see if it goes a little farther and latches the park mechanism. always start with the repair that doesn't require buying parts. then go to the repair that requires cheap parts. then look into whether or not you need an expensive part.
Old Apr 20, 2020 | 10:05 AM
Cdbarber's Avatar
Cdbarber
great advice. Love not spending money if I don’t have to! Thx.
Old Apr 20, 2020 | 09:17 PM
Cdbarber's Avatar
Cdbarber
So I took all you guys said to do and found the problem. I took the shifting bracket off and saw there was a peg on the back side that was hitting the edge of transmissions pan. It was not allowing it to go all the way into park. I ground down the extra peg and boom. It works. I’m going to assum me the kid I bought it from put the wrong bracket on. I have looked at that before, but did not pay much attention to it. Thank you all for your recommendations. I’m deaf not a mechanic lol. But I’m learning.
Old Apr 21, 2020 | 03:35 PM
domenic tallarita's Avatar
domenic tallarita
Originally Posted by jackson
My guess also.
dom
To Park not working
