"howling" noise when not accelerating
Old Apr 25, 2020 | 05:35 PM
johnny76's Avatar
johnny76
Cruising
Default "howling" noise when not accelerating
Hi,
When i hit about 45 MPH and take my foot off the accelerator, i hear this low "howling" noise (no idea where it's coming from though likely underneath the car). If I just tap the gas, no noise. take the foot off the gas, the noise comes back. Only happens when I get up to 45MPH and disappears after 60MPH. I ruled out any type of "wind" or air noise as it only happens when i accelerate (even the slightest touch of gas peddle). One mechanic thought it may be the differential, but given it only happens in this small range and otherwise the car is driving OK, that it's likely not a big deal. Thoughts?
Thanks Johnny76
Old Apr 25, 2020 | 06:10 PM
cv67's Avatar
cv67
St. Jude Donor '05
Could be the diff but if its not bad and in a small range leave it be
aftermarket gears can be noisey
Old Apr 25, 2020 | 08:57 PM
GTR1999's Avatar
GTR1999
Could be pinion bearings but as mentioned new gears, even US gear will make a noise in the 45-60 mph range once letting off acceleration. US Gear now prints this out in the spec sheet with new gears.
Old Apr 25, 2020 | 10:00 PM
l82vett's Avatar
l82vett
Sonds like a bearing set up wrong or going bad in the differential to me. Usually the pinion bearing. Got a rear seal leak? maybe low on gear lube.
Old Apr 26, 2020 | 07:49 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I agree on checking the lube. Check the tranny level as well. If you cant identify where it is and you want to, I would fill the diff and then drive it. Then fill the trany and again, drive it. Then check all the u joints for grinding or stiffness but you have to get the rear half shafts to a level relative to the diff that wont let them bind. And grease them if they have zerk fittings then drive it again. If that doesnt do it you can check bearing play but you have to jack up the rear again and have a helper. You need to determine bearing play and not confuse it with the half shaft movement. I agree with the others that if its a small mph range and not an RPM range then i wouldnt worry about it until it gets to a point you can identify it to rectify it. To check rpm, if you can hear it, get the car up to that speed in a different gear and/ or check the rpm in the given gear when the noise appears and get the car up to that rpm in a differnt gear and see if it appears. If its just speed related in that gear at that speed it still could be a tranny gear but the chances get lower.
Old Apr 27, 2020 | 05:24 PM
bazza77's Avatar
bazza77
In my 77 I had a 3.08 to 1 which had a distinct whine at 60 km/h , not 59 not 61 ! ! ! ! apart from that it went ok. I sold the diff to a guy during my car rebuild as I got a 3.36 to 1 to use . I told him there's a problem with it before I sold it but he wanted to change gear ratio anyway so it was ok. Anyway he opened it up and the pinion gear was in 2 pieces !!!
To "howling" noise when not accelerating
