70 LT1 distributor again pics
Last pic is of a 69 1111491 with the rubber bushing I'm used to seeing. Notice all the space still in the slot. Has a 536 weight. The problem I'm having is setting total advance, as the mechanical never stops advancing post 4k. Stock setting is 26 degrees max mechanical. Ideas?
69 distributor
The second picture looks like a home made bushing.
You need a spring kit with a bronze replacement bushing.
Try the silver and black springs to start with, 928 Mr Gasket
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
I have the spring kit. Also the 28b vac can. Tried both per Duke, but I think my carb had issues. Had it rebuilt and installed. Ready to try again.
I've been trying to get someone to I d the cam weight number. The 540 on mine is incorrect since 26 degrees is the spec. Yet to get an answer. The 69 in my post pic has a 536 which seems to be all I'm seeing. Like to sort all this out before I start the changes again.
you've been very helpful thank you
You are very fortunate. Not only for having a 70 LT-1 (congrats!) but for having a very short "slot". Most people have to weld theirs up to achieve this, you do not! I went thru a lot of effort to "tighten" up my slot from about 0.140" to 0.095" .You should really do a "performance tune-up" on the distributor. It will really wake the car up and make it roar! Good gas dependent of course.
Lars has great info on setting up the distributor curve.
I set my own up in my home garage as shown here: https://www.corvetteforum.com/forums...ing-chart.html
My 70 LT-1 that I drove hard for 27 years, loved initial timing. I know I ran 36 total at 3500, and IIRC inital was around 12-15? My vac can was limited to 10 degrees and it ran on manifold vacuum, not ported. It gained a lot of TQ below 3000 rpm with those settings, vs factory, and then it roared once past 3500. With true 11:1 CR I did have to pull it back 4-6 degrees to get it to run on 93 pump gas. That took like 30HP out of it. But it ran fine. The "track-tune" was never more than 5 gallons of race-gas away.
Thanks for all your input.
Look underneath for the cam number: 530 or 722 etc. 30 degrees or 22 degrees. I have two now, one of each.
This is the 530 cam. It had 30 degrees advance and this much open space in the slot.
530
No I let the LT-1 go after 27 years. It was in a Z28 anyway. When I got the Vette after a 10 year "car" hiatus I decided to go bigger, LS6!
If so your gap should look like my 530 cam.
Can you measure that gap with a dial caliper? My math says your gap should be 0.120" to give you 26 degrees. That and 8 initial is 34 total. Not bad just comes in at really high revs due to the stock springs.
1983 GM Parts Book
from Dave Fiedler at T.I. Specialties
1983 GM Parts Book
Yes I have a 1111491 distributor. The cam weight in is 540. I cant find a 526 to fit the spec of my distributor. The GM part number for the cam is GM #1967928 That has a 530 stamping. Don't get it?????
The fact that the centrifugal advance comes in very late is because of the stiff factory springs. Even if you want to keep it 100% stock, you don't want to rev it to 5000rpm + to set the timing!!
I'd suggest use the two weakest springs from an advance curve kit, and then you can set the timing at a more reasonable 3000 rpm. Change the springs back when you are done. They should not have any other effect except for the rpm.
Now if you do that and find you do not get 26 degrees mechanical advance when the distributor moves, you may have to build your own distributor degree wheel like mine and figure out what is going on.
Glad you liked it!
It is actually attached near the tach drive, just has vertical supports to move it up over the rotating parts. I just kept adding cardboard and tape until it was stable. The copper wire pointer is wrapped around the two advance weight pins so it moves. All I turned was the gear, and the wire pointer moved smoothly. Modified my total mechanical advance and my vacuum advance. It worked very well. Especially for cardboard LOL. I could read it to 0.5 degrees consistently.
figure I can rig this up to the 491 on the engine and move the cam weight instead of the mainshaft for obvious reasons
If I read that right it looks like you have exactly 10 degrees advance (distributor) which doubles in the engine to 20 degrees (crankshaft)
I never even thought about using this setup while the distributor is installed in the car, but I guess you could, that's a good idea! As long as you can reach & rotate the right part without making everything "wiggle".
That's a good distributor curve. Mine started with almost 30 degrees.
So if that "536" means 36 degrees is that rubber bushing what is shortening the degree read?
The bushing on your TI looks original it was hard nylon? plastic and looks like you still have a retainer clip. Not so much the 69 one.
So now you can just set your initial timing and you will know what the total really is.
6 degrees initial would give you 36 total etc.
Now the real question is how much timing will that 11:1 CR LT-1 really like without pinging on today's premium?
I needed 5 gal of race track 113 octane to run 36-38 total in mine.
I would guess no more than 32 total on pump gas. Just going by what mine liked.
For you 2 initial.
Are you sure you want to keep this 100% stock?
A performance curve in the distributor would help it run better at mid-range. Just sayin'
For you 2 initial.
Runs good . Idles like crap. All the tinkering has a lot of unburned fuel ,(smoke),out the exhaust .
When I got the car timing was 6 degrees. Manifold vacuum went to the choke. Someone drilled a port vacuum and ran a line to distributor. Idle was crap, DC isnt run all that well with a slight light stumble on acceleration.
think I might change out distributors to see what effect that might have.
Maybe try a 2nd distrib, that's a good idea, 'cause you don't want to mess with the original TI one, I get it.
I'd suggest near 18 degrees initial, with another 10 degrees on vacuum, with the vacuum on manifold. That would give you 28 initial at idle and it would really like that.
The vacuum advance has to be pretty much cut in half to do this, with a vacuum advance limiter, it just screws on. $6
But to run 18 initial you need to weld up the slot in the mechanical advance to cut that 30 degrees mechanical back to about 18 degrees. That's a pretty serious/permanent distrib mod. Then you could run 36 total. With 5 gal of really good octane (you shouldn't need a whole tank) it'll run terrific.
An electronic MSD distrib would make this really easy, or maybe you could just borrow a tuned one to try it.
I pulled the timing back 4 degrees to run pump gas (32 total) and bumped it back up when I had access to Cam 2.That alone made a 30HP difference. Ran it for 25 years that way. The last 8 years I didn't Autocross as much so I didn't ever put the Cam 2 in it.
That engine is Spotless and Beautiful! Keep it running like it should.
