Interesting QuickJack problem
Old Apr 29, 2020 | 11:34 PM
Devs77's Avatar
Devs77
Default Interesting QuickJack problem
I used my QuickJack extensively on my AC project. I took it all apart to back the car out of the garage to run it a little to make sure the belts were good, etc.
Now that that project is done, I'm on to cleaning the engine bay and undercarriage, so I went to put the lifts under the car and make the hose connections only to find that I couldn’t push the hoses onto the power unit. I emailed QuickJack and they said to hold the “Down” button while connecting the hose. It worked like a champ!
Hopefully this might help someone with this issue down the road.......
Old Apr 30, 2020 | 08:08 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I have that problem occassionally, the pressure must build up in the cylinder and hose and just needs to be vented....
Old Apr 30, 2020 | 08:52 AM
interpon's Avatar
interpon
And if you force it..it will leak a little fluid..so i hold my down button about 20 seconds to be sure..even without air in cylinder it will collapse..
another tip..they say you can but don’t stack blocks
Old Apr 30, 2020 | 09:40 AM
Devs77's Avatar
Devs77
That’s a good tip. I used to stack them, but after reading some of the other experiences here not any more.
Old Apr 30, 2020 | 12:11 PM
scottjamison's Avatar
scottjamison
Yeah stacking them scares the poop out of me. No way!
Thanks for the tip. It hasn't happened to me yet but I am sure it will at some point.
Old Apr 30, 2020 | 12:34 PM
L-46man's Avatar
L-46man
Yup! they're pressurized fittings.... I get the same problem when I try to connect air power tools and the compressor is at 125psi.
Old Apr 30, 2020 | 01:25 PM
Devs77's Avatar
Devs77
Another useful little tidbit: from full down to all the way up (the locks secure on the second, or highest setting) the bumper of the car moves almost exactly 10 inches fore or aft depending on which direction you have the lifts facing.
One guess as to why I felt the need to measure......
Old Apr 30, 2020 | 04:54 PM
scottjamison
Somebody unintentionally tested the structural integrity of the garage door?
Old Apr 30, 2020 | 05:37 PM
Devs77's Avatar
Devs77
Good guess!
To Interesting QuickJack problem
