73 AC won't charge.
Old Jun 2, 2020 | 04:06 PM
khigley's Avatar
khigley
Default 73 AC won't charge.
Need some help with my AC system on my 73. I installed a new S6 compressor, which is much lighter then the old A6 also installed the VIR Eliminator to convert over to 134a. I evacuated the system and it will hold a vacuum forever, so I have no leaks. The problem I am having when I go to charge the system is that it will take a can and a half of 12oz 134a and both low and high pressures go to 100psi and stop.. I know the low side should be around 30 to 40 psi and the high should be around 250 give or take. This is with a jumper on the compressor to make sure the clutch is engaged which it is. What am I over looking or doing wrong?
Old Jun 2, 2020 | 04:44 PM
SwampeastMike's Avatar
SwampeastMike
Bad or missing expansion valve? Without a functioning expansion valve there is nothing for the compressor to work against.
Old Jun 2, 2020 | 07:03 PM
khigley's Avatar
khigley
VIR Eliminator, does away with the expansion valve..
Old Jun 2, 2020 | 08:45 PM
interpon's Avatar
interpon
well whatever is in there is not restricting the flow to vaporize it just before the evaporator...
or your compressor is not compressing...
i wouldnt jumper the clutch for long only to test..
did you put lube in? Did you manually circulate the compressor to clear oil?
You could also have let air in...
i would pull vacuum again and start over....
luckily its cheap and not r12 like mine
Old Jun 3, 2020 | 10:03 AM
SwampeastMike
Old Jul 6, 2020 | 11:36 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Do you have long tube headers ? If you do the A/C lines either touch the exhaust tubes or are very close and will not allow the A/C to work as the exhaust temps heat up the A/C lines
With LT's you have to bend the A/C lines so you have at least a1/2 inch clearance from the lines and the exhaust tubes
Old Jul 7, 2020 | 07:05 AM
68blvert's Avatar
68blvert
Bad orifice in VIR kit. No pressure differential, no cold air.
Old Jul 7, 2020 | 07:23 AM
derekderek's Avatar
derekderek
I think more likely bad comptessor. More to go wrong with a compressor. Easier to swap out and return, too...
Old Jul 7, 2020 | 09:13 AM
68blvert's Avatar
68blvert
Possibly bad compressor. Wouldn't rule it out but even a bad compressor that can only build 100 psi would have 5-10 psi on low side if orifice was good unless your pressure readings are actually static pressure with the clutch engaged in which case I would agree with a wiped out compressor.
Old Jul 7, 2020 | 09:20 AM
derekderek's Avatar
derekderek
the 100 psi is the slightly overcharged base pressure in the system.
Old Jul 7, 2020 | 10:42 AM
carriljc's Avatar
carriljc
Swap out the orifice and try again. It's a cheap part and simple to do. Not to mention that R-134a is relatively inexpensive so I would suggest going this way.
To 73 AC won't charge.
