1977 a/c question
Old Jun 4, 2020 | 11:02 AM
maynard22's Avatar
maynard22
2nd Gear
Default 1977 a/c question
I am looking at buying a 1977 Corvette and the A/C unit is all intact and there minus the belt. What is my worse case scenario cost wise to get the A/C working like it should, parts and labor?
Old Jun 4, 2020 | 11:24 AM
Bikespace's Avatar
Bikespace
Worst case? Hiring someone to do it, and it needs everything, $2K seems to be the consensus. For that much, you could swap in a Vintage Air system.
What does the rest of the car look like? Have you checked the birdcage for rust?
Old Jun 4, 2020 | 11:30 AM
maynard22's Avatar
maynard22
2nd Gear
Here is the link to the car, not sure if you have facebook for it to work
https://www.facebook.com/marketplace...ssenger_banner
Old Jun 4, 2020 | 11:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Looks like a reasonably nice car. Ask the seller why the belt is off the AC compressor.
Old Jun 4, 2020 | 08:37 PM
HeadsU.P.'s Avatar
HeadsU.P.
Had my '77 switched over to the new gas, some parts, etc by a certified shop. Condenser and compressor were ok. Cost around $400 for parts / labor.
Your biggest enemy will be a heater control valve competitively letting heat in the cabin. And a blower motor that barely moves the A/C around.
Never did work / cool right. Ended up removing the heavy compressor.
Old Jun 4, 2020 | 08:47 PM
Bikespace's Avatar
Bikespace
This is exactly the kind of information I like to see.
So what do you think it would have cost to have fixed the system correctly (with R134A)? Comparable to a Vintage Air system (for comparison purposes, that's $1500-, plus installation).
Old Jun 4, 2020 | 09:24 PM
interpon's Avatar
interpon
If you do the work yourself 1000 below the price you would pay for the car with working ac...
2000 if someone else does it..
that puts you into the zone of cocern regardless of why he tells you belt is off..
push the schrader valve and see if anything is in it...if so your odds just improved..
Old Jun 5, 2020 | 08:04 AM
KenSny's Avatar
KenSny
Belt is off because compressor is squealing, or clutch doesn't work, etc. No matter what he tells you.
If hoses were taken off for an radiator or engine removal, and the system was left open, he didn't want to spend money to recharge.
The system does not hold a charge because of leaking seals.
Could even be the console controls are messed up, shorting, etc.
You won't know until you tear the system apart. Have fun!
Old Jun 5, 2020 | 08:05 AM
HeadsU.P.'s Avatar
HeadsU.P.
Certified A/C tech guy showed me with temp gun, 68* coming out of the vents. So he did his job replacing parts. Just not much flow behind the vents. I suspect years of crud blocking the duct work. Or a blower fan jammed up. IDK. Never tore apart the dash to inspect.
Wish I never put the money into the A/C at the time, really not needed. A year later found out the heater control valve did more harm than good and put in a manual shut-off. Meanwhile the compressor had been removed. Had $400 into the system.
If I need A/C now, just put windows down, remove T-Tops and drive by a fresh water ocean ( No sharks- No salt)
Old Jun 5, 2020 | 09:39 AM
DavidandJoansVette's Avatar
DavidandJoansVette
Veteran: National Guard
Converted my 77 to R134a last summer. Several parts plus the conversion kit from Zip. Cost right at 600 parts and labor. Worked ok for 3 weeks until compressor blew. New compressor was 299 plus tax and shipping from Zip. It is being installed Monday morning. Estimated installation is 150. So I will be well over a grand as of Monday. HOPEFULLY this fixes it. I do not expect it to freeze my extremities like new car units do. Hope this helps.
Old Jun 5, 2020 | 09:50 AM
bruiser's Avatar
bruiser
St. Jude Donor '15
On my 77 I replaced the R4 compressor a couple times before i got a sanden compressor which has been working good for over 5 years. The R4 compressors are junk.
Old Jun 6, 2020 | 02:10 AM
Giddy-up Go's Avatar
Giddy-up Go
Ask about the birdcage! Get pics. Be sure and read the 10 Rules here on the Forum before buying! Good luck.
Old Jun 6, 2020 | 11:39 AM
brucksch's Avatar
brucksch
For that price I'd sell my 77 and the A/C works!
Old Jun 6, 2020 | 09:34 PM
jackson's Avatar
jackson
don't have a 77 but silver facebook's too high.
Old Jun 11, 2020 | 11:34 AM
DavidandJoansVette
Just picked up my 77 from the shop. Compressor install and R134a came to 264. I am now well past 1200 in ac work. Still need a piece of ductwork which ranges from 60 used to 85 new. Then comes the hard part of installing it.
To 1977 a/c question
