C3 frame
Old Jun 6, 2020 | 08:34 AM
Chris Bolling's Avatar
Chris Bolling
8th Gear
Default C3 frame
Hello, are all of the C3 frames the same can I use an 1980 frame on my 1969 4 speed body?
What is the difference between the years if there are any?
Old Jun 6, 2020 | 03:40 PM
ACfarmerNH's Avatar
ACfarmerNH
Some changes along the way... I'm modifying a frame from a '74 to work on my '72.
Take a read through these:
http://www.71corvette.com/frames.html
http://www.bairscorvette.com/techinf...fications.html
Old Jun 7, 2020 | 08:20 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
heres some other info too
https://www.corvetteforum.com/forums...-question.html
some cool upgrades
http://www.mycorvetterestoration.com...p#.Xtzao-d7k2x
Old Jul 3, 2020 | 09:20 PM
1artgtr's Avatar
1artgtr
7th Gear
My son & myself just changed the frame on my 1976 Vette, The car needed a lot of work. I bought some one else’s failed project about 1-1/2 years ago. Picked up a 76’ frame for $600. In great shape. Luckily previous owner bought a some of suspension parts it needs.
Old Jul 4, 2020 | 03:07 PM
jpatrick62's Avatar
jpatrick62
One difference is the thickness of steel in the 1980 versus 1969 frame. The frame up until 1980 used 0.11 thick steel while the 1980+ frames used 0.90 thickness steel for better gas mileage (lighter weight).
Old Jul 4, 2020 | 07:08 PM
68/70Vette's Avatar
68/70Vette
I don't think a 80 frame is going to work well on a 69. The frame attachments for the front and rear bumpers are completely different. The 80 has rubber bumpers front and rear, the 69 has steel bumpers front and rear.
In 1980, I ordered from GM a 1969 Corvette frame. It was stored as another car part in my collection, until in about 2004 I decided to use it as a frame for my 1970. I was surprised to find that the front bumper supports for the 70 would not fit. Also, some extra 68 front bumper supports would also not fit. This was baffling since from what I knew, the 68 and 69 front bumper supports werer the same. What was going on? I called the usual Corvette vendors, asking what was going on. No one knew, until I started talking to Volunteer Vettes. They have a lot of frame parts. I got a call back with the news. In 1980. if you ordered a 1968, 1969, 1970, 1971,1972, 1973 frame from GM, they shipped you a 1973 frame!!!! Although the 1973 has a rubber FRONT bumper, the attachment hardware was very similar to the previous Corvette years, it was not exact. With a drillling of a two bolt holes, or a little welding, a 1968 through 1972 front bumper can easily be mounted to a 1973 frame. The 1974 frame, for use with front and rear rubber bumpers is much different front and rear than the 1973 and previous years. Once again thanks to Volunteer Vettes for doing all this research!!!
Old Jul 6, 2020 | 11:23 AM
L-46man's Avatar
L-46man
Chris; basically the answer is NO.
As others have said the front and rear bumper attachments are completely different.
Of equal importance is in 1980 Chevy was on a huge weight reducing impetus. They lightened up the frame from .110" metal thickness to .090" metal thickness. which indeed dropped the weight of the frame close to 150lbs, but made it weaker.
The Rear cross member also attaches in a different way.
Stick with the 69-73 frames.
Unkahal
To C3 frame
