Dizzy/vac can???
Old Jun 8, 2020 | 08:02 AM
JavaJolt78's Avatar
JavaJolt78
Default Dizzy/vac can???
To all C3 Gurus!!!!
Vacuum can hose routing to ported or manifold source???
78 stock L48...
JJ78
Old Jun 8, 2020 | 08:40 AM
HeadsU.P.'s Avatar
HeadsU.P.
Ported is emissions crap.
Manifold (full vac) is performance non-crap.
Pick your port. Usually off of the front of fuel / air blender.
Old Jun 8, 2020 | 08:46 AM
JavaJolt78's Avatar
JavaJolt78
Ok HUP,
Tx for the info and as I remember ported is above the throttle butterflies and manifold is below???
Perhaps you can suggest the best one on my Qjet???
JJ78
Old Jun 8, 2020 | 08:47 AM
BLUE1972's Avatar
BLUE1972
Pull a vacuum line while the engine is idling. If there is vacuum it's manifold
Old Jun 8, 2020 | 09:20 AM
HeadsU.P.'s Avatar
HeadsU.P.
Sorry. Have not owned a QJ since the 70's. Not my thing. I prefer the Holley blenders.
Once you find your correct port, cap the other. That little trick should gain you over 2.74 H.P.
Old Jun 8, 2020 | 07:45 PM
HeadsU.P.'s Avatar
HeadsU.P.
Originally Posted by JavaJolt78
Ok HUP,
JJ78
Just my opinion but, the "best" canister is an adjustable unit.
The canister itself doesn't care if you have a QJ, Holley, Q. Fuel or Eddy.
The canister wants a specific vacuum range to operate in depending on the amount of vacuum your engine is pulling at different throttle positions.
Old Jun 9, 2020 | 06:23 PM
7T1vette's Avatar
7T1vette
In almost any case, you want vacuum advance connected to manifold vacuum.
_______________
Just something to think about---
Many 'performance' folks have great disdain for vacuum advance. Why? I'm not sure. When at WOT, the vacuum advance [for all practical purposes] has no effect on ignition timing. Manifold vacuum is nearly ZERO at WOT, so no change to ignition timing because of the vacuum advance. The purpose of vacuum advance is to obtain a smoother idle, lower engine temps at idle, and better economy at idle and low speed cruising. That should be an asset to anyone.
To Dizzy/vac can???
