Front clip removal question
Old Jun 16, 2020 | 06:43 PM
BEJ's Avatar
BEJ
Default Front clip removal question
Hi all,
Maybe this belongs in the paint and body section but I have been pondering something and wondered if someone has an answer. Is it possible to remove the front clip with the engine in place? I have seen plenty of pictures of removed clips and the bare firewall, and have read tutorials on the process. In all of the pictures I have seen, the engine bay is empty. I have serious poor alignment issues with the front clip along with a growing portion of the bonding surfaces that are coming undone. I am going to be painting soon and need to decide the approach to take with the clip.
Thanks,
Bryan (BEJ)
Old Jun 16, 2020 | 06:59 PM
20mercury's Avatar
20mercury
I would say yes you can I have removed a front clip, but to tell you the truth, I could not remember if the engine was in it or not.
Check the AIM for the bonding places you need to split or undo.
Old Jun 16, 2020 | 07:30 PM
crf311's Avatar
crf311
Yes it is possible, but much harder. Chech our Dynamic Corvette on you tube. They have a video doing the clip removal. Use a heat gun. Make it a lot easer
Old Jun 16, 2020 | 07:43 PM
BEJ's Avatar
BEJ
I will check that out. I installed vintage air so the passenger side is pretty accessible with the heater box gone. It's the driver's side that has me concerned. I just don't see a way to get to the firewall bonding area on that side.
Old Jun 16, 2020 | 08:08 PM
BEJ's Avatar
BEJ
Just watched that video. They really make it look easy.
Old Jun 16, 2020 | 11:26 PM
standardbyke22's Avatar
standardbyke22
i removed mine with the engine in, i used a heat gun and a coupe of metal scrapers one soft one hard. the worst part was separating the front flange near inner fender area. i got a crack on both sides near fender to top surrond bonding strip. otherwise went well and reused clip, set clip with car on all 4 wheels properly inflated.
Old Jun 16, 2020 | 11:48 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Rookie advice: Take your time with the heat gun and a long-handled gasket scraper.....no sense in cracking good fiberglass
Long handles...............short handles.......you'll probably need an assortment.
Old Jun 17, 2020 | 12:48 AM
20mercury's Avatar
20mercury
Default Agree and good advice.
Agree and good advice. When I removed the front clip off a 69, I think I had a half dozen of the ones doorgunner shows on the right. With a heat gun you can start on each side with a scraper or putty knife and work towards the middle tapping with a hammer. Eventually the glue seam will pop open. Easy to get outside the glue seam and into the fiberglass so agree patience is needed.
To Front clip removal question
