‘77 mirror removal
Old Jun 17, 2020 | 12:54 PM
San Diego Ron's Avatar
San Diego Ron
Default ‘77 mirror removal
After seeing the post by (sembiker) asking if glass has to be removed to tighten chrome mirrors, I want to ask same question about removing sport mirrors.
At some point someone had mounted mirrors with the wedge shaped gasket wrong and mirrors are almost touching window glass. With door panel off rear bolt is hidden behind glass, does someone have magical way of doing this without removing glass?
Old Jun 17, 2020 | 01:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You may not have to remove the glass, but you will have to be able to lower it far enough to get it out of the way. Check the lower stops to see if you can lower them.
Old Jun 17, 2020 | 03:41 PM
interpon's Avatar
interpon
try this if like a 79..slide post 6
https://www.corvetteforum.com/forums...questions.html
To ‘77 mirror removal
