C3 Power Steering Pump Data Overload
My requirements:
1. Work with my Steeroids rack that wants to see a pump ideally in the 1,000 - 1,200 PSI range and NO MORE THAN 2 gallons / minute (Steeroids says that flow rates greater than this causes the fluid to overheat and the rack to prematurely fail unless you are also sending the fluid to a cooler or a hydroboost unit.)
2. Work well with an aluminum pulley: No spinning the thing off as things heat up and cool down.
3. Work in the stock mounting location with stock brackets
Nice-to-haves:
1. Shiny chrome reservoir
2. Reservoir in original "canned ham" style that came on my 79
IMO, #2 means that I should NOT be using a pressed-on pulley although March and Billet Specialties seem to make one, the difference in the rate of heat expansion of aluminum and the hub just seem like a bad idea and a recipe for throwing off a pulley.
Saginaw Pump Specs Over the Years:
- P Series
- 1964-1974 SAE threads; SAE inverted flare fitting; 5/8" keyed shaft with woodruf keys to hold on pullies
- 1975-1979 SAE threads; SAE inverted flare fittings; 3/4 PRESS ON shaft
- 1980+ Metric threads; metric o-ring fitting, 3/4" PRESS ON shaft
- The can styles, necks, caps, clocking, and return hose fitting placement vary between vehicles so stick with C3 Corvette-specific pumps. Some of the specs vary across the years in C3s, too so see C3-specific info below.
- NOTE: Pressures of many aftermarket pumps are WAY higher than stock (1,400 even 1,500 PSI); C3s all came with around 950 PSI pressure and stock hoses are only designed for up to 900 PSI presssure...
- Type 2
- The successor of the P Series pump; just listed to mention NOT THESE!
Corvette Saginaw Pump Specifics:
- 68-74: SAE threads, SAE inverted flare fitting 5/8" keyed shaft w nut and woodruf key; "Long Neck" can
- 67-69 flow rate: 1.75 gal / min
- 70-73 flow rate: 1.6 gal / min
- 74 flow rate: 2.9 gal / min
- 75-79: SAE threads; SAE inverted flare fitting; 3/4" PRESS-ON pulley; "Canned Ham" style reservoir
- 75-79 flow rate: 2.9 gal / min
- 80-82: Metric fittings; "Metric" stamped on outside; spam can reservoir; M10x1.5
- 80-81 flow rate: 2.9 gal / min
- 82 flow rate: 1.9 gal / min
Big questions I have: Mounting Brackets and spacing (pulley distance from block) -Are the mounting bolts / brackets different across the years? -I'm assuming that the spacing is the same as accessories I believe are all spaced the same across the years.
Thoughts on selection:
I've seen some supposed "Corvette" Saginaw P power steering pumps that support keyed pulleys and nuts from the earlier pumps but the canned ham -style reservoirs. This seems like the way to go for me as I want an aluminum pulley and I think theyr'e safer with a keyed pulley rather than a press-on, AND the earlier pumps don't exceed the recommended 2 gallons per minute of the Steeroid rack...
Adam
Don't know if this is the one they used but it looks similar: https://www.performanceonline.com/Ad...ng-Flow-Valve/
Maybe this will give you some more options.
DC
Seems to match everything I need. Now I just need to find an aluminum pulley for it...
Hunting pulley specs...
Adam
My requirements:
Nice-to-haves:
- P Series
- Type 2
Adam
https://www.turnone-steering.com/
DC
Adam
DC
I found the MFGR. They patented this, which is why all of them seem to look the same regardless of who sells them: https://www.heidts.com/part/adjustab...-valve-ps-101/
Adam
It's not about reliability of a stock pump. It's about custom cars and custom applications where the steering feel is not ideal. It's a solution to a problem that many people have when building custom hot rods. As far as one more thing to fail, that's what I said when someone told me I should ditch the Borgeson system and go back to the factory system
DC
I'm looking for almost the exact same requirements in the power steering pump / pulley that you were. Could you send me a link to the pump and the pulley so I could take a look?
Thanks in advance...
KT
