Wanna be mechanic needing help
1980 4 speed
So am replacing some vacuum lines and doing some basic stuff under the hood and I don’t know what this does or what hooks into it. Any help and/or guidance would be appreciated!! Thanks in advance.
The heat riser is not needed unless you are driving in the snow. If it is closed, it forces all of the passenger side exhaust through the intake and out the driver side exhaust. Good for warming up the engine quickly, but bad for peformance and vapor-lock. Below is a photo of how it should look with no vacuum to compare to the position of your lever (yours appears to be open). If you apply a vacuum to that port, the valve closes. It's easy to check the function with a vacuum pump, but you want it open!
The flapper(s) in the cold air intake are driven by that thermo-vacuum switch. Again, they should fail open (check). I've removed the flappers entirely by driving out the large pins in the dual-snorkel air filter housing. When operating correctly, they will balance "cold" air from above the radiator with warm air from the heat stove around the exhaust manifold. In practice, and assuming you don't drive in snow, when would you ever want anything but the coldest air possible going into your engine?
The same goes for any TVSs in your waterneck. I've replaced mine with a simple waterneck with no threaded holes (GM Part 10108470), since I don't need the temperature-sensitive vacuum lines to go anywhere.
Have you done the Lars-style tune, and ensured that you are getting (full-time) manifold vacuum to your distributor's vacuum advance?
I will also take tour advice on the distributor vacuum advance and work on it tonight.
I was searching for a broken vacuum line, because my blower only blows out in the floor, and that lead me to about a million other little things!!
https://www.ecklers.com/1977-1982-co...-106582-1.html
see post 23
https://www.corvetteforum.com/forums...-switch-2.html
