C3 Calipers / brakes
Didnt see the glowing rotor like on a frozen calp
Wouldnt need the whole master to empty. Looks a little low.
Question: what would cause no fluid to come out of the brake lines when I pulled the calipers? Is that normal? I thought when you disconnect the calipers then the brake lines they drip brake fluid. Always had as far as I remember. Still have fluid in the master cylinder.
1. Ignition switch: You should see the light illuminate when you crank the engine.
2. Parking brake: You should see the light illuminate when you pull the handle up.
3. Combination Valve switch: If either half of the brakes have failed, a piston will slide to one side or the other inside the combination valve, blocking fluid flow to that half of the circuit (front or rear), as well as grounding the brake light in your dash, causing it to illuminate.
If your brake light doesn't come on in the previous two scenarios, it's a good chance it was disabled. You can test continuity in the switch on the combination valve, and make sure it is still connected.
Here's the description from the 79 Shop Manual. Do you have a copy for your car?
I have the 74 manual but it doesn't have a diagram of the combo valve. I'm googling it now.
Also can i simply hook the whole system back up and do a basic bleed process or are C3s more complicated.
Can I simply do this?
1. re-assemble
2. fill liquid
3. open 1 bleeder / someone pump brakes till full stream / close bleeder
4. Repeat on all 6 bleeders.
Even if your calipers don't leak, if you have lines/hoses filled with air instead of brake fluid, and you press the brakes, the "proportioning section of the combination valve" will detect this pressure imbalance, skew to one side to prevent further leaks, and allow braking with only the other two calipers (front or rear, opposite of where the problem is). If your brake light is illuminated, and you are not cranking the car, and the parking brake lever switch is not engaged (lever up), then, yes, you have a problem.
I'm not 100% sure how you reset the combination valve at this point. There is a tool that keeps it centered, but I don't know how to get it centered without bleeding the brakes and solving the problem, and I don't know how to bleed the brakes with the combination valve off center.
BTW, your 1974 does not have a "check engine" light, but it should have a "brake" light on the dash.
The method poo-pooed in the video (opening up the working brake circuit, then hitting the brakes hard), may work. I haven't tried, but I'd search the Forum for additional tips.
Here's the tool that will keep it centered, once you center it.
I may have opened the MC cover and that caused it? I def didnt touch the brake pedal. I poured enough fluid in to make sure air doesnt get it. It never fully emptied.
I got the pistons out- nasty looking. Emptied 2 cans of brake cleaner on them. The pistons look OK. Noticed one of the piston rubber seals was installed backwards.
that assumes that the parking brake light is adjusted correctly and not triggering the light as well
No, when I removed the calipers i just taped off the end of the SS brake lines so they wouldnt leak all the fluid out while I rebuild the pistons.
If you depress the pedal to the floor your will push the pistons and cups in the M/C PAST the normal 'swept volume area' and probably kill the M/C.
I actually plan on just re-assembling the whole system and see what happens. I'm missing 1 seal set and the new bleeders. Waiting for it to arrive from the retailer. Once I get it I'll install all and start from the back. See If i can get fluid to the rears. If not then I'll have to screw around with the comb valve and see if I can get it to center.
