With halfshaft, strut rods, shocks off, should the trailing arm be able to be rocked back and forth (top goes in, bottom goes out) with all the shims in. Or are my bushings bad?
Edit: the bushing stays put. But the trailing arm moves in it.
Not quite sure on your description but if you are saying that you can twist your trailing arms by hand on a vertical axis then your bushings are past gone. Since you have everything disconnected, this would be the time.
okay let me try to clarify. I can flex the entire trailing without anything connected to it. The bushing can move in the cavity. It is shimmed and ready to go. The TA flexes while the bushing stays still. Also, i forgot to mention i just put new bushings on it. Did i not get them on far enough? The trailing arm doesnt flex in and out but like a bad wheel bearing. You can grab it (with some force) and basically twist it back and forth. Sorry if im confusing. Not good at explaining things.
The trailing arm will move in a somewhat spherical motion.
The movement is not strictly up and down the arm twists in the bushings slightly as well, because of the squat of the car there is some radial action.
The front of the T/A should not move at all (1) Vertically, or (2) Sideways (Left/Right) or (3) Front/Rear. Once it is tightened down. And the front T/A bushing should only be torqued down when both the T/A arm and the half-shaft are in their normal level ride-height position. Or the bushing will tear.
However you should be able to (1) lift the rear of the T/A Up/Down; and also (2) rotate the front of the T/A at the bushing like a clock. It should rotate to maybe 10 o'clock and 2 o'clock. Now both this rotation motion and lifting motion should be somewhat stiff, not loose. Because you are actually flexing the rubber in these two cases.
