Droopy Sunvisor
Old Aug 4, 2020 | 01:31 PM
fatboy999's Avatar
fatboy999
Default Droopy Sunvisor
I have a sunvisor that won't stay up, it keeps dropping down. Is there a way to repair this problem, or a repair kit for this problem?
Old Aug 4, 2020 | 02:10 PM
CAMS69's Avatar
CAMS69
i pulled the shaft out of the visor ( wiggle and pull, maybe add wd40) then i squezed the clamps inside the visor some, roughed up the shaft a bit and reinserted. Worked great for me
Old Aug 5, 2020 | 07:20 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I did it the same way
Old Aug 5, 2020 | 07:46 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
For my 68, I removed the end pins smacked the visor gently.... operative word here is gently with a plastic mallet.
Reinserted the end pins which fit snug and no more auto deployment.
Marshal
Old Sep 13, 2020 | 05:03 AM
C3Highway's Avatar
C3Highway
That’s consistent with my experience. With a loose visor, it can generally be as simple as just compressing the clamps inside the visor with pliers, which will usually tighten it up quite a bit. A little bit can go a long way, so compress gently and then test the tension by working it.
Conversely, if the visor is too tight, drop a bit of penetrating oil down the shaft, and then work it. Once it loosens up to just right, I’ve noticed it will tend to stay that way.
Old Sep 14, 2020 | 06:59 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I think you can tighten the philipshead screw....if that doesnt help, use the fixes other members have suggested.
To Droopy Sunvisor
