Coolant change
Old Aug 19, 2020 | 08:48 PM
nickster2213's Avatar
nickster2213
Default Coolant change
I have read many threads on this subject, and not sure I am going to attempt removing the two block drain plugs from engine. My 1980 has115,000km on it and have done the Prestone flush then fill with 50/50 mix more a few times. Plugs look like a big pain on the 350 small block.
Old Aug 19, 2020 | 10:16 PM
interpon's Avatar
interpon
Not a chance would i take them out..
flush and fill is fine unless it sat without changes for a long time...imo
even dump from radiator and refill more frequently using purified water or pre mix...some say if always hot area..more water than antifreeze like 60/40 as opposed to 50/50...
use the green stuff..i made mistake of the gm dexcool after radiator heayer core fix...was told no go..here
Old Aug 19, 2020 | 10:25 PM
nickster2213
Yes I was thinking the same, I have always did coolant change on a regular basis. Will stick with it.
thank you.
Old Aug 20, 2020 | 12:27 AM
Bikespace's Avatar
Bikespace
Here's my 80 L48 with 116,000 miles. Both plugs came out, no problem. It probably helped that I had the exhaust out at the time.
To Coolant change
