1968 Correct Engine suffix code
Old Aug 26, 2020 | 09:08 AM
Steve 427's Avatar
Steve 427
Default 1968 Correct Engine suffix code
For a 68 327/350 what is the correct code? I have seen people say HP and then some say HT ? Were both correct?
Old Aug 26, 2020 | 09:48 AM
gbvette62's Avatar
gbvette62
"HT" is the suffix code for a 68 327/350. "HP" is the code for a 327/300 with AC, PS and manual trans.
Old Aug 26, 2020 | 09:50 AM
7T1vette's Avatar
7T1vette
Both HP and HT could be used for the 327/350hp engine. HT was applied for manual transmission car without A/C and/or Power Steering. If the car received A/C and/or P/S, the engine got the HP code.
Old Aug 26, 2020 | 12:48 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
This one I know. There is a lot of bad info out there on 68 codes on different sites.
HT is 327-350hp WITHOUT AC
HP is 327-350hp WITH AC
I have owned my L79 (HT)since 1985. NO AC. I also had an L79 (HP) WITH AC and no PS. I believe the current judging manual has it right. HP code is not shared with any 300hp car in 68.
Old Aug 26, 2020 | 03:58 PM
Steve 427's Avatar
Steve 427
Thank seems to make sense.
Old Aug 26, 2020 | 03:59 PM
Steve 427's Avatar
Steve 427
Sounds about right. Cars with AC had a HP code but still 327/350.
Old Aug 26, 2020 | 04:08 PM
gbvette62's Avatar
gbvette62
So when did this change?
I know the Corvette Parts Books were always vague about this, only saying 327 with Hyd. Steering & C.A.C. (car air conditioning) - HP, and 327 with Special High Performance - HT, but the NCRS has always listed HP as a 300 horse and HT as 350 horse. I have at least 3 NCRS books, going all the way back to the 1989 Restorer 15th Anniversary Edition, 1953-1972 Specifications Guide, that all show "HP" as a 300 with AC and "HT" as the 327/350?
I don't have a need for it, so I don't have a current 68-69 Judging Manual. I think there may now be a 5th Edition of the pocket size, 68-82 Specifications Guide, I guess I'll have to get one to replace my 4th Edition one!
Old Aug 26, 2020 | 04:27 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
hi,
Not sure when NCRS made the correction but pretty sure the latest edition is correct. I was also going by the L79 I own and the other I did own. My longtime L79 is a non AC (HT) and the other ( also very orig 50k mile 1 owner) was an AC L79 ( HP).
Old Aug 26, 2020 | 04:33 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
Also, If I recall, the 300hp cars are HE for a manual trans and HO for auto.
Old Aug 26, 2020 | 06:20 PM
bbvette427's Avatar
bbvette427
NCRS 5th edition
HP 327/350. Manual w/PS & AC Q jet
HT 327/350 4spd. Sp. Cam Q jet
Old Aug 26, 2020 | 08:09 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Depends on the book...the answer is yes
Old Aug 27, 2020 | 11:12 AM
bigredbrad's Avatar
bigredbrad
From: Lincoln NE Riding and Driving Corvettes since 1967.
I own a 1968 L79 with factory A/C no power steering.
The original Flint yellow grease pencil markings are visible on both sides of the engine block and are "HT"
The engine ID pad is also stamped HT
Bigredbrad
Old Aug 27, 2020 | 04:30 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
Bigredbrad
Ok, that is strange. Do you have a build sheet? Any pics of the AC set up?
Old Aug 27, 2020 | 06:36 PM
bigredbrad's Avatar
bigredbrad
John - Yes, I have a build sheet that shows all options including C60, L79 & M21.
Original compressor, evaporator case, condenser, core support, copper radiator, etc.
Bigredbrad
Old Aug 28, 2020 | 07:36 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
Bigredbrad
Wow,
Next question. The L79 C60 (HP) I had was a very late car ( Aug 68). I did not have a build sheet but I had the original window sticker and dealer paperwork. Is you car on the other end of production (early)? Just trying to figure out if the factory changed the suffix at some point.
Thanks for the info. Have a great weekend! AJ
Old Aug 28, 2020 | 12:39 PM
bigredbrad's Avatar
bigredbrad
Wow,
Hi John -
Yes, this particular car is a December 67 build.
I also have a March built 1968 L79 AC and I will try and look to see if it is HP or HT
Have you done a survey of vins to determine if there is a pattern or have you started to determine a date change from HT to HP?
I have been doing research on 1968 fan shroud and radiator usage with C60 A/C option. Maybe we should collaborate our information?
Bigredbrad
Drivers Side Flint HT markings under original paint
Passenger side Flint HT markings two times under paint. Also was marked HT on the end of one head but I cant find that photo right now.
To 1968 Correct Engine suffix code
