Jacking C3 one side
Old Aug 28, 2020 | 01:01 AM
Corpor's Avatar
Corpor
Default Jacking C3 one side
If I use the jack point 5" from the front wheel, will I be able to lift the back at the same time? Changing wheels, no jack stands, just a floor jack with a large disk.
Old Aug 28, 2020 | 06:10 AM
Bikespace's Avatar
Bikespace
I'd use two jacks for that. Alternatively, if you are very careful, you can lift the front, or rear, of the car as a whole via the front crossmember (susceptible to crushing) or the rear differential (likely blocked by exhaust).
It is best not to twist these cars, or tip them over sideways.
Old Aug 28, 2020 | 08:28 AM
HeadsU.P.'s Avatar
HeadsU.P.
This is really a bad idea. Frames will stress / twist and make noises that would scare Freddy Kruger. When you need to lift the front or rear, go in steps or increments of several inches at a time. In other words, moving your floor jack back & worth several times is the forgiving way to do this.
Old Aug 28, 2020 | 09:31 AM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
If you jack from the front cross member as Bikespace suggests, us a large board to prevent the cross member from crushing. You want the outside seams to support the load not the center which will most likely collapse/crush.
Old Aug 28, 2020 | 09:47 AM
Corpor's Avatar
Corpor
I am perceiving lifting from the front with the 5" rule, the whole side should lift. I just have to try and see since I am doing it shortly...
Old Aug 28, 2020 | 09:51 AM
Corpor's Avatar
Corpor
I've read the manual carefully. This vagueness is crazy, they should put a mark on the frame from factory on cars where the jack point is! How hard is that!
Plates, pucks, 5" from the door edge...
Old Aug 28, 2020 | 09:52 AM
71yellow454's Avatar
71yellow454
I put a single floor jack lifting from the side just in front of the trans cross member. Lifts front and rear tires about the same time, then a jack stand under the lower control arm in front and just in front of the rear wheel in the back. If I am just changing tires I don't even use jack stands, Have been doing it this way for years and never had a problem.
Old Aug 28, 2020 | 10:44 AM
Corpor's Avatar
Corpor
Corpor's Avatar
Corpor
Does this look correct?
Old Aug 28, 2020 | 11:01 AM
DC3's Avatar
DC3
My '73 has a stiff enough frame that I can put the jack anywhere between the two tires and lift one side easily with both tires off the ground. However, when I do that I prefer to put the jack closer to the middle between the two tires and keep it away from the transmission cross member.
DC
Old Aug 28, 2020 | 04:41 PM
Corpor's Avatar
Corpor
I took it to a tire shop I trust, done deal...
Old Aug 28, 2020 | 04:59 PM
Shovels and Vettes's Avatar
Shovels and Vettes
Drives me crazy when I see people using a jack, with the metal dish just up against the frame. It will not only chip paint, but will also most likely dent the frame. Use a wood block, rubber pad, or one of those hockey pucks made for this and you can keep from damaging the frame. I powdercoated my frame on the rebuild, and the dumbasses at the alignment shop just scratched and dented the crap out of it. Every time I allow some one to touch my car, they screw it up somehow. Today there is a difference between a car mechanic and a true craftsman.
Old Aug 28, 2020 | 05:34 PM
L-46man's Avatar
L-46man
Do not lift the car corner to corner. You MUST lift the 2 jacking points individually and at the SAME TIME.
Trying to be very clear here.
Old Aug 28, 2020 | 07:11 PM
Corpor's Avatar
Corpor
I was getting a headache reading details on how to jack the car up, so I went to the tire store, but thanks. Rather use the glucose on something else.
Old Aug 28, 2020 | 08:24 PM
HeadsU.P.'s Avatar
HeadsU.P.
Well, there you have it. Case closed. Story over.
What some forgot to mention is that in rare cases the door gaps / fitment can change due to the stress on the improper jacked frame. They usually will return to normal spacing, once back on the ground. But, never know.
Old Aug 28, 2020 | 08:34 PM
Bikespace's Avatar
Bikespace
There is certainly no shortage of opinions on this site.
If you work on your car, you may find a second floor jack, a set of jackstands, and ramps helpful. Here's my 79, halfway onto jackstands. Note the 2x8s under the rear wheels for clearance. From this position, I can lift the rear to get onto jackstands, then lift by the front crossmember to get the whole car elevated. No twisting, rocking, or side-lifting required.
Driving these cars is more enjoyable than working on them, but I do enjoy both!
Old Aug 28, 2020 | 08:35 PM
Redvette2's Avatar
Redvette2
When I went to get new tires put on they opened all the doors and hood before they lifted the car!
To Jacking C3 one side
Old Aug 28, 2020 | 08:55 PM
Corpor's Avatar
Corpor
They did that today at the tire shop. Then they asked me to pat my head and rub my belly in opposite directions, and walk around my car counter-clockwise!
Old Aug 29, 2020 | 03:44 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Even though you solved this at the tire store, pick up a pair of jack stands. They'll come in handy some day and you will be safer for whatever you do, whatever vehicle you are working on. (If I were purchasing now, I'd opt for the stands with the pin through the central shaft.)
Old Aug 29, 2020 | 04:32 PM
20mercury's Avatar
20mercury
Default And all while chewing gum???
All while chewing gum, no doubt. If the cops did that when they pulled you over, nobody would pass and we would all be at the station!
