View Poll Results: Is your 1981 CCC working?
Yes, controls everything as the factory made it
10
41.67%
Yes, but carb, dizzy and torque converter only
4
16.67%
Removed it for alternate system
10
41.67%
Other
0
0%
Voters: 24. You may not vote on this poll
Survey: 1981 Computer Command Control
Old Aug 28, 2020 | 08:37 AM
Yadkin's Avatar
Yadkin
Default Survey: 1981 Computer Command Control
Of those who own an '81, is your CCC in or out?
Old Aug 29, 2020 | 11:55 AM
larryg3's Avatar
larryg3
My CCC is in for now but i plan to change the carb and dizzy and the Auto trans will be replaced by a TKO 500 during the winter.
Old Aug 29, 2020 | 12:28 PM
81BLACKVETTE's Avatar
81BLACKVETTE
My CCC is in. Only dizzy,carb and torque converter. Been that way for the last 10 years.
Old Aug 29, 2020 | 06:04 PM
Mark G's Avatar
Mark G
All original here! (and restored)
Old Aug 29, 2020 | 09:25 PM
ramair_bryan's Avatar
ramair_bryan
I'm a little late, what else is it suppose to control?.....................
Old Aug 29, 2020 | 11:06 PM
MattoonVette's Avatar
MattoonVette
Living the Vette life....
Mine is out and in it's place is an Edelbrock Pro Flo 4 and 4L60E transmission.
Old Aug 31, 2020 | 09:16 AM
Yadkin's Avatar
Yadkin
Some emissions equipment.
Old Sep 1, 2020 | 12:32 AM
ramair_bryan
Ain't none.............
Old Sep 1, 2020 | 06:29 AM
Reaper19's Avatar
Reaper19
Mine is still in and have it all working. The PO removed the air pump, but gave it to me when I bought the car and have it stored. Went thru a lot of fine tuning of the carb after rebuild, but have a scan tool, Monitor 85 to help read codes and keep everything in the CCC running correctly.
Old Sep 1, 2020 | 06:39 AM
Antz81's Avatar
Antz81
Carb and diizy only for me. 4 speed manual so no torque converter
Old Sep 1, 2020 | 04:59 PM
spedaleden's Avatar
spedaleden
Out
When you remove computer harness remember the the power wire for the compressor is in the computer harness so remember to remove it.
Running a GM crate motor with carb, electric fans, serpentine belt, distributor and 5 speed
To Survey: 1981 Computer Command Control
