Help ID Ignition Shielding
Old Aug 28, 2020 | 04:50 PM
SVASSH's Avatar
SVASSH
St. Jude Donor '21
Default Help ID Ignition Shielding
I bought what was listed as 1974 Ignition Shielding. What I got is I think a basket of parts mixed and matched. Any help with identification is appreciated. I have looked online but most of the vendors photos show only the distributor cover or all the parts mixed together.
I think this is correct 74 Vette Distributor Cover
I think these are from a C2 63-67?
Are these the spark plug looms for a 74?
No clue, anyone?
No clue, anyone there are 3 of these
No clue, anyone? pretty small
Old Aug 28, 2020 | 06:42 PM
gbvette62's Avatar
gbvette62
The first picture is a 70L-74 top box and supports.
The second picture is a either a 64-65E, 65 or 66-67 327 top box, and right vertical shield.
The third picture of the two wire supports, don't look like Corvette parts to me.
The forth picture is a lower V plug wire shield, that holds the wires against the block, and away from the exhaust manifolds. I'm just not sure if it's a 63-69, or 70-75, and if it's a left or a right.
The fifth picture is of the spark plug heat shields that go between the plugs and the manifolds. They were used from 57-80, but there should be a forth one.
In the last picture, the top item looks familiar, but I can't place it, but I don't think it's part of the shielding. The rubber coated four wire support in the middle is a 62-64 right rear lower wire support, that mounts to the rear of the block, behind the right side head. The small, rubber coated two wire clip is lower plug wire clip, that mounted on the block, one on each side.
