jack stand with the quick jack
Old Sep 21, 2020 | 03:29 PM
Bills17n72's Avatar
Bills17n72
Default jack stand with the quick jack
hello friends ,does anyone put jack stands under their car when they use the quick jack,I do?
Old Sep 21, 2020 | 04:15 PM
L-46man's Avatar
L-46man
Yes...in a way but not for the reasons you do.
1. I use the quick jack all the way up and LOCKED
2. When all the way up and LOCKED I use two screw type trailer jacks to remove the weight from the rear overhung cantilever rear and most importantly in the front to remove the weight of the engine.
3. The screw jacks are placed under the engine cradle (with a stout 4x4" block and about 300 lbs is on it.
4. In the rear I also use a 4x4" block under the rear bumper 'bar'...the last cross member.
5. This allows the car to sit in natural repose and allows the doors and etc NOT to have any strain on the hinges or latches.
Unkahal
Old Sep 21, 2020 | 04:33 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
I do like the way Bill has it as it will prevent a sudden drop if the quick jack hydralics fails suddenly.
I have a quick jack too and like it very much.
Marshal
Old Sep 21, 2020 | 04:47 PM
BKbroiler's Avatar
BKbroiler
I don't.
BTW if the Quick Jack is being used as per the instructions, the car is not being held up by hydraulics, the Quick Jack frame is resting on one of the two mechanical stops. You could remove the cylinders and the car wouldn't move.
Old Sep 21, 2020 | 06:58 PM
interpon's Avatar
interpon
Originally Posted by BKbroiler
I don't.
nor do i..
and the only way you could use stands would be the screw type..which now that im thinking about would like some..
impossible to get jack stands right height without screws when quick jack sits on locks..a set height.
good source for screw stands? I thought aboit hydraulic for third hand but could use with quickjack on components of weight..
op do not use jack stands under quick jack while hydraulics pressurized!!
those jack stand youhave cannot support car as they are not that adjustable to hold weight...maybe as a fail safe fall..
Old Sep 21, 2020 | 08:45 PM
DC3's Avatar
DC3
I keep wheel cribs under the tires when using the QuickJack if possible. My wheel cribs are tall enough that if the QuickJack failed, the car would only drop an inch or so. I lower the car onto the wheel cribs when I want the QuickJack out of the way for better accessibility. If I needed to work under the car with the tires off, I would definitely use jack stands somewhere to catch the car in case the QuickJack failed. I just don't trust manufacturers so it's up to me to be as safe as I can be.
DC
Old Sep 21, 2020 | 09:45 PM
Bills17n72's Avatar
Bills17n72
the jack stands are all the way at their lowest point
Old Sep 21, 2020 | 10:15 PM
Mooser's Avatar
Mooser
I use two stands at the front of the frame to take some of the weight, if I'm going to have it up for any real length of time. I raise the jack all the way and then put the stands under the frame as far ahead as I can and I've got a pair of hardwood wedges that I put it to compensate for the notch heights of the stands and a piece of rubber mudflap material to hopefully protect the paint. Then I lower the jack down onto the bar-stop.
I don't add any other stands unless I'm going to be under there pulling and pushing something heavy. I don't think I've heard of any QJ failures (when use properly, mileage may vary, etc)
M
Old Sep 22, 2020 | 12:56 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I do not use jack stands with my quickjack because when properly used it is mechanically locked in place.
However, if the car will be up on the quickjack for an extended period of time, I will use a pair of jack stands to support the cantilevered weight of the front end.
Old Sep 22, 2020 | 05:14 PM
interpon's Avatar
interpon
It is a tricky thread...
you cannot set weight on stands AND allow for the quickjack to mechanically lock for sure..and not on hydraulics...UNLESS you let it rest then as some do put a jack under and shim after , or screw jack, or crib wheel and lower qj
if you try to guess when lowering quickjack it may not lock and or rest on hydraulics.
i also learned the hard way do not use double rubber blocks..if not aligned ( qj parallel as it lifts) well they flung out on me..luckily onthe vette the frame of the jack catches the frame.
if op has jack there loose to catch the qj...maybe ok..
Old Sep 22, 2020 | 06:14 PM
Bills17n72's Avatar
Bills17n72
ok guys I set the quick jack on its first lock with no pressure on the two cylinders ,then I slide the jack stands under the car ,the jack stands are at their lowest point ,
To jack stand with the quick jack
