77 factory heat choke question
Old Sep 26, 2020 | 07:12 PM
bleverman's Avatar
bleverman
Default 77 factory heat choke question
I'd like to get the heat choke working on my 77. I'm unsure as to what parts I'm missing. Maybe someone can help me. Pictures are super helpful! I believe I already have the intake manifold heat choke tube (shown with green circle). Thinking I only need tube going to choke assembly and tube going to carb. Am I missing anything else? Also, what is supposed to go where the yellow circle is? Thanks in advance!
Old Sep 26, 2020 | 08:11 PM
MelWff's Avatar
MelWff
You need the two tubes.
Yellow circle would be EGR valve.
https://willcoxcorvette.com/corvette...w-gasket-75-77
Old Sep 26, 2020 | 09:02 PM
bleverman's Avatar
bleverman
Thanks!
Old Sep 26, 2020 | 09:03 PM
bmotojoe's Avatar
bmotojoe
Along with the missing EGR valve I see 4 other parts.
It looks like you have the lower choke tube installed. Part Number 343769. To be sure it is clear, blow a little compressed air through it.
1. The fresh air tube. Part Number 14006748 1975-1980. I don't think this tube is being reproduced.
2. The Upper choke tube. Part Number 355918 1976-1980. Check corvette vendors. I think this is being reproduced.
3. High Temp hose (Silicone). I don't have the number off hand. Make sure a replacement is made of something other rubber. The steel tube gets real hot.
4. Is just a standard vacuum hose.
Old Sep 26, 2020 | 10:03 PM
bleverman's Avatar
bleverman
Thank you bmotojoe. I was wondering how to connect them. I did find both tubes at Zip Corvette.
Old Sep 28, 2020 | 11:21 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You know, at this point you could easily install a 2101 Performer with 1204 gaskets that block the heat riser and convert to electric choke....it is a Non-EGR intake and about 1/2 the weight.....a small perfromance improvement too.
The original heat riser system is a miserable thing.......spend the money you would spend resurrecting this terrible system on a real intake manifold and electric choke. Put a heat rise valve delete spacer in the passenger exhaust manifold too.....you will be glad you did.....it is not a question of if this will fail, it is a question of when.
Jebby
To 77 factory heat choke question
