Bryar Blue
You may elect to hire a painter who is experienced in color matching to work the process through to having a couple gallons mixed up.
Under side of the gas cap, behind the lower rear window trim, and behind one headlight bezel are the only locations I think I saw original paint and the gas cap has since been repainted.
The other 2 spots just look too much like overspray to really get a good idea.
My car was painted with Glasurit and all I can say is yes, it's beautiful but trying to match it is a chore. For example, I think the guy that painted my car may have prepped the metal pieces the same as the fiberglass so the primer was actually losing contact with gas lid and side fender grilles.
I had those 3 pieces repainted using a scanner and the RH grille and gas door look real close, almost no need to blend (and I haven't yet- maybe when driving season is over) but then the LH grille is like blue green on a blue green purple car. It matches when I lay on the ground but when I stand up the car changes color but the grille doesn't.
It sounds like you may have already heard what you need from someone else but I have nothing else to do at this hour.
The one I did see was at stop light outside Fort Myers. Small block coupe - my car's twin.
What are the odds...
Oh, and my most valuable tool in my garage is touch up paint that matches.
