Manual transmission lube
Old Oct 16, 2020 | 09:10 AM
SSG26K's Avatar
SSG26K
Default Manual transmission lube
I have a '72 LT-1 with 4 speed tranny. I want to change tranny gear lube. I have some 80W90 that says good for non-synchronized transmissions with OEM spec API GL-5/MT-1 oil. My '72 Chevy manual lists SEA 80 or 90 GL-5 gear lubricant. Are these compatible, or is there an additive left out that should be in a synchronized tranny or is it understood that it is okay for regular synchronized transmissions?
Thanks for any advice you can add.
Old Oct 16, 2020 | 10:57 AM
fastimes's Avatar
fastimes
St. Jude Donor '19-'20-'21-'22
Changed out my 72 M-20 gear oil a few hundred miles ago with this. Old school GL-4 oil for an old school gear box. Shifts smooth as ice cream.
Old Oct 17, 2020 | 12:39 PM
Crimson Thunder's Avatar
Crimson Thunder
I use the exact same thing in my Muncie. Driven GL-4
Old Oct 18, 2020 | 08:53 AM
stingr69's Avatar
stingr69
Your owners manual does not spec GL5.
Old school GL4 is best for vehicles that were originally spec'd for it. People will tell you what they have had sucess with but you can't go wrong using the stuff it was originally designed to use. It just works right.
I tried a heavily advertized brand of expensive synthetic GL5 for a few days in a fresh built Muncie that I put together. It made more noise, leaked and did not shift a smooth as it should. Drained it out and put CHEAP generic parts store GL4 conventional gear oil and never looked back. Don't fall for the hype.
Old Oct 18, 2020 | 10:57 AM
Bikespace's Avatar
Bikespace
Red Line makes synthetic GL-4 gear oil (Amazon Link). I use it in my B&W 4-speed, and in the differential.
Old Oct 18, 2020 | 03:43 PM
buckybadger45's Avatar
buckybadger45
Penn Grade 1 makes a GL-4, 80W90. I use it in both my 66 and 72 corvettes.
Old Oct 19, 2020 | 09:39 AM
rberman999's Avatar
rberman999
If you have a Napa parts store they sell the Sta Lube in the GL4 80-90W for the old manual transmissions. You might need to order it but it is a one or two day delivery to the store. Good luck, Russ
To Manual transmission lube
