Valve Covers
To our dismay the valve covers are leaking like a sieve.
We have installed Dart Iron Eagle heads and some trans dapt valve covers with rubber gaskets. We also used the longer hold downs.
What can we do?
What can we do?
Did you use gasket sealant on the gasket to the cover?
Did you check if the flange was straight?
If sheet metal have to you tried spreaders under the hold downs?
All that top-end oil pools around the valve-spring pockets before draining out. A too short of ledge puts the oil just that much closer to the cover gasket. Especially during acceleration / cornering.
Not a big fan of rubber or pure silicone gaskets. They have no pores. Therefore you can never use an adhesive / sealant. Where as, a cork gasket has thousands of pores and will accept an RTV easily. But pure cork has issues too.
Why not compromise and use both? Composite gaskets from FelPro are finely ground up cork and silicone pieces mixed together then formed to shape. They will take RTV, retain their shape and not shrink and seem to handle hot oil better.
1. clean ALL oil & grease from the gasket surfaces on valve covers AND BLOCK!
2. If you choose to use sealant on the gasket, put a very light wipe of it on BOTH sides of the gasket; use ONLY Permatex #2 gasket sealer.
[Allow sealant to cure overnight before firing engine]
3. Apply as little bolt torque as will seal the gaskets (50-75 INCH-pounds...no more).
Using too much bolt torque is the #! KILLER for valve cover leaks...especially for stamped metal covers.
Clean and dry sealing surfaces are very important with rubber gaskets. Any
sealant that is applied, will act as a lubricant.
You can "glue" the gasket to the valve cover with ultra-black permatex rtv. Put a couple heavy books on top of the cover as clamps, until it is cured.
Seals, and won't leak, if given half a chance.
Also, as stated before, check your bolt length, and make sure your covers are straight.
If they are steel, generally you can flatten them.
Aluminum? I can't say, as the only experience I have with aluminum valve covers, is with heavy duty truck engine valve covers. They are a very heavy casting, and don't warp. They also used captured rubber or re-inforced rubber gaskets.
Good luck with your project.
Jeff
