Correct part name
Old Oct 22, 2020 | 06:14 PM
burkh's Avatar
burkh
Default Correct part name
What is the correct name for this part?
Shock mount? Where can I get a replacement? Has anyone ever seen one bent like this! Sure surprised me , as I was taking things apart to replace the trailing arm bushings .
Old Oct 22, 2020 | 06:25 PM
Duke94's Avatar
Duke94
Rear shock mount.
https://www.zip-corvette.com/63-82-r...unt-w-nut.html
Old Oct 22, 2020 | 06:28 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Lower Rear Shock mount. (Left or right )
About $50.00 Most Vendors sell them.
Old Oct 22, 2020 | 06:31 PM
OldCarBum's Avatar
OldCarBum
Bair's Corvette.
Old Oct 22, 2020 | 06:54 PM
L-46man's Avatar
L-46man
Bubba came along and said...
"Where should I jack the car up??? (entirely in the air) I know, the rear shock mount!"
sigh!
unkahal
Old Oct 22, 2020 | 07:51 PM
burkh's Avatar
burkh
Thanks guys, for your quick responses!
Old Oct 23, 2020 | 07:00 PM
gbvette62's Avatar
gbvette62
Bair's Corvette.
Bair's has their own made here in the US. If you're buying them from someone else, ask whose they are or where they're from, because there are foreign made ones available too. The foreign made ones appear to be of good quality, and cost about the same as the ones from Bair's, so why buy the overseas ones.
Old Oct 23, 2020 | 07:19 PM
bazza77's Avatar
bazza77
Isn't there two different sizes ? Not left or right , but didn't they change thread size sometime along the run ?
Old Oct 23, 2020 | 08:24 PM
firstgenaddict's Avatar
firstgenaddict
F41 cars use a different shock mount, it is "offset".
IIRC the regular cars use 2 different forgings (left and right) and the F41 piece is a single forging machined for left and right.
Old Oct 23, 2020 | 08:43 PM
NONN37's Avatar
NONN37
Sometimes they can get damaged because its one of the lower hanging parts on the rear.
from the car dropping on a flat, hung up on a curb with enough of the sidewall compressing or the wheel falling into a pothole.
Old Oct 23, 2020 | 08:55 PM
ronarndt's Avatar
ronarndt
My 68 convert had different right and left shock mounts.
Old Oct 23, 2020 | 09:33 PM
carriljc's Avatar
carriljc
Willcox lists a LEFT and a RIGHT....
are you sure it's bent????
new ones look about as "bent" as the OPs.
https://willcoxcorvette.com/corvette...-rear-rh-63-82
Old Oct 24, 2020 | 11:29 AM
jhudec's Avatar
jhudec
I believe I may have a spare set if interested. Let me know and I will try and find them.
Joe
Old Oct 24, 2020 | 12:28 PM
burkh's Avatar
burkh
Joe
I ordered a pair yesterday.
Appreciate your support!
To Correct part name
