One of the bolt holes for the hood hinge is stripped out (in the hood). Any ideas on how to repair this? Could I just tap it and create new threads, or is there more involved with this?
Thanks for the replies. If I can't get this tapped out, I may need to go to a helicoil. I did find that there is a metal plate with threads in it which is riveted into the hood, so I'll give the old tap a try and see what happens.
I'd heli-coil (or timesert) if it was me
Epoxy thread repair is pretty light duty and next time you pull the bolt it might be toast again. If I wanted to go this way I'd look at putting a stud in so I didn't disturb it next time (and do the other side so it looks slight less Bubba)
Before drilling out a side, see if a 8mm x 1.25 bolt won't work, it's slightly larger in dia and almost the same pitch. Use some loctite and don't torque it too hard though
M
