Window Installation
Old Oct 26, 2020 | 02:06 PM
VinniePG's Avatar
VinniePG
Default Window Installation
1975 coupe. I took out my driver side window to put in a new regulator. It is power. Regulator installed and works perfectly. My problem is getting the window back in. For some reason, I cant get the roller on the window to go into the window opening, it is wider then the opening. It is a new roller and exact fit as the old one.. What should be a simply procedure has me puzzeled. I know once I get the roller in, I have to screw the window to the track. My window has all new parts. Please give me some of your expertoize. thank you
Old Oct 26, 2020 | 04:01 PM
Peterbuilt's Avatar
Peterbuilt
Could it be that the 'studs' are too long?
https://www.corvetteforum.com/forums...r-my-71-a.html
