I am in the process of preparing my 75 for paint, using the razor blade method to remove paint. Is it necessary to remove the red oxide primer in order to get to glass or can the factory primer be painted over so long as it is in good shape? This question isn't about whether or not it is best to go to the glass or not, just whether or not it is necessary. I appreciate any input you can give.
I think the old primers are laquer base. and sometimes modern paint systems can react to it and may problems down the road. So thats usually the major issue
But if it is in decent shape. some people do paint over it with good results, the problems are usually reactions which cause the old finishes to fry up, or new sealer finsih not adhering well.
I would try to still remove as much as possible(to help adhesion) and lay down a really good epoxy sealer as a base. Usually it says something on the Tech sheet of how to prep for certain stuff. If the paint starts to fry up or activate something youll know it aint gonna work.
I would advise againt using the razor on the primer. its usually softer so it doesnt scrape off as easily. as the weathered topcoat. and youll just end up gouging the panels with the blade. i would sand it down. I used stripper on mine and sanding.
Thanks for the reply. The paint really does fly off with the razor blade, it truly is amazing. I have heard that the primer can be taken off with Acetone and scouring pads. Maybe I'll give that a try, or not. I will make a decision once all of the paint is off. I may end up finding surprises that make the decision for me.
I did exactly what you did with a razor and I sanded the red oxide and used epoxy primer over it. In the past I have used many different paints over the red without a problem. How did your finger nails hold up? got some paint under mine.
