Exploder rivets
Old Nov 8, 2020 | 05:48 PM
kossuth's Avatar
kossuth
Default Exploder rivets
I am about done fixing the floor on the drivers side. Unfortunately I have to put all new insulation clips on the entire car because the jackass that owned the car before my younger brother just ripped the underside insulation off and cut tabs etc. It's a mess. I have the new clips and such but looking for a way to elevate any future pain and misery. In short I dont want to:
1. Remove the remaining insulation, seat, and so on to install the new aluminum rivets the OE way. Everytime I look into something on this car I end up finding something else that's screwed up.
2. Enlist my wife or oldest daughter to help me peen the new rivets over. (Will be an epic bitchfest).
My oldest brother whom is an autobody guy and also works on dirt late models on the weekend turned me onto these things. Looks like it would work but wanted to see if anybody has used these on fiberglass. They work kinda like a pop rivet but curl over on the backside pulling against kinda like a toggle bolt. They use these things to attach the nose pieces to the front of a dirt late model so I'm certain they are plenty strong. Thoughts?
https://behrents.com/parts/bsc-90030...kaAqheEALw_wcB
Old Nov 8, 2020 | 06:19 PM
dmaxx3500's Avatar
dmaxx3500
just go buy the ''RIGHT'' aluminum rivits
make sure there annealed,,i got mine from the corvette place in michigan [paragon],
they go right in,using an air hammer,turned down
Old Nov 8, 2020 | 09:39 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I used aluminum pop rivets, back up washers, and some JB epoxy to hold everything in place long enough to go back an forth between the interior and underneath to the interior again. Once the jute and carpet are over top, the slight bump from the rivets is undetectable.
Old Nov 8, 2020 | 09:50 PM
96GS#007's Avatar
96GS#007
Just tossing these out as another alternative...
General Purpose Split-Type Rivets For GM 11516807
Available on Amazon for ~$20 for 25 of them
LINK LINK
GM uses these to attach the front splitters and side skirts on the C6 ZR1, C7 GS, Z06, and ZR1. They have a larger head than standard rivets. No idea if this will work, just happened to be cruising the C3 section since years ago I had a '78 and an '80 and saw the thread
Old Nov 9, 2020 | 12:39 AM
20mercury's Avatar
20mercury
Me, just added tunnel insulation to my 68 project with original L79 and Muncie. And I used ss screws/nuts with fender washers to secure the insulation. Better than the original fold over tabs, under the carpet on top and wow you would almost have to pull the engine to see on the bottom. I would have been the only person to ever know, except of course, I am now telling the Corvette Forum, ha! You can likely just pull the carpet back enough to get access to the ss screw or nut on the inside. Hope this helps.
To Exploder rivets
