China wall seal failed
Old Nov 9, 2020 | 07:47 PM
Jim71Vette's Avatar
Jim71Vette
Default China wall seal failed
For years I used the rubber end seals with RTV when installing intake manifolds. About 25 years ago I used rubber end seals and RTV to install a Edelbrock 2101 on my 71 L48, never a leak.
When I rebuilt the L48 I installed a new 2101 and succumbed to the hype and just used RTV. I used Permatex Ultra Black gasket maker and made 1/4" beads on front and back walls, following Edelbrock 's instructions. Guess what? It leaks... from the back...not much but still a leak. Front seems OK. So... getting ready to redo it and thinking of using the rubber end seals. Did I use the wrong RTV? Maybe larger beads?
Jim
Old Nov 9, 2020 | 09:59 PM
MelWff's Avatar
MelWff
Did you let it cure for a few minutes before installing the intake?
Old Nov 9, 2020 | 10:36 PM
Jim71Vette's Avatar
Jim71Vette
Cleaned both surfaces with scotch pad and lacquer thinner and let RTV skim over... about 10 minutes.
Old Nov 10, 2020 | 12:42 AM
7T1vette's Avatar
7T1vette
When using such sealants, it requires placing the intake on the block and inserting all the bolts down FINGER TIGHT and letting the sealant cure overnight. THEN you apply torque to the bolts...in stages....so they pull down evenly. If the surfaces which seal are cleaned well before installing, they should not leak.
When intakes (or other such parts) are fully assembled with 'soft', uncured sealant, there is no resistance left in the sealant to prevent oil from wicking out. Also, the soft sealant actually acts as a lubricant (rather than a sealant) until it is cured.
Old Nov 10, 2020 | 12:55 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Long shot: can you re-clean the leaky area with acetone.....
then force fresh rtv into the leaky area with a flexible body filler spreader or even your fingers....
the let the new rtv cure at least 24 hrs before starting the engine.
Old Nov 10, 2020 | 02:57 AM
Haggisbash's Avatar
Haggisbash
My method is to run the bead of high temp silicone, allow this to skin and then put a wipe of fresh silicone over this then tighten down the manifold as 7T1vette describes. So far I have not had a leak using this method. I believe the fresh sealant on the skinned allows the sealant to "key" to the surfaces better. JMPO
Old Nov 10, 2020 | 07:45 AM
fastimes's Avatar
fastimes
St. Jude Donor '19-'20-'21-'22
I have zero experience doing this, but have been reading up as it is on my "to-do" list.
Many folks here have recommended Permatex "The Right Stuff" for sealing china walls. Don't know how it differs from Ultra Black.
Old Nov 10, 2020 | 11:23 AM
Stoge's Avatar
Stoge
I could be 100% wrong, but I believe The Right Stuff can be put in service much sooner than Ultra Black. Everything I've done with ultra black needs 24 hours to cure before driving.
Old Nov 10, 2020 | 11:29 AM
Jim71Vette's Avatar
Jim71Vette
I thought about doing that, but decided to just redo it.
Old Nov 10, 2020 | 11:37 AM
Jim71Vette's Avatar
Jim71Vette
This makes sense. But thinking of switching to the "Right Stuff" for faster cure time.
Old Nov 10, 2020 | 11:38 AM
VF-301's Avatar
VF-301
2024 C1 of the Year Finalist - Modified
I've had 100% success using "The Right Stuff" on everything I've used it on.
Old Nov 10, 2020 | 11:57 AM
Tiger Joe's Avatar
Tiger Joe
x2 i only use right stuff on these. never had a leak
To China wall seal failed
