Brake Options
Old Nov 17, 2020 | 08:14 AM
thread baron's Avatar
thread baron
Default Brake Options
I wanted to see if anyone could provide some feedback on best options for repairing the brakes? I have an original 70 LT-1 and have not had it out and really put any miles on it in the last couple of years. The fronts are sticking a bit and I don't know that the brakes have ever been addressed on the car. I know there are a lot of options from rebuilding the original calipers, replacing them altogether, upgraded rotors, etc. I just want to get it back to being a fun daily driver. What options have you taken (good or bad) and which direction would you suggest? Any feedback is appreciated!
Old Nov 17, 2020 | 08:57 AM
gguillot's Avatar
gguillot
Need more information to really give you a good answer. When you say the front brakes are "sticking" - what do you mean? Do you have a solid pedal? Are the rotors simply corroded from not being used? If that's it, just drive it - the pads will clean the rotors up. If the car has truly been sitting for a long time, you may have other issues, but first lets find out if your brake system is holding pressure - so - do you have a firm brake pedal?
Old Nov 17, 2020 | 09:10 AM
thread baron
They are spongy and it was sitting for a while.
Old Nov 17, 2020 | 09:44 AM
HeadsU.P.'s Avatar
HeadsU.P.
A basic brake "tune-up" would be new pads, four new rubber hoses and a complete flush with DOT3. Then go from there to see if the calipers, rotors or master have issues.
You need to take a turkey baster and remove the old brake fluid from the MC. But not every ounce. Leave a little in the bottom to avoid air pockets later.
Top-off the MC w/ new DOT3.
Change out the four hoses. As you are doing that, new, clean fluid will begin flushing the system so keep an eye on the MC fluid level.
Install new pads by squeezing caliper pistons with bleeders cracked open and a piece of clear hose in place.
You can let gravity flush everything for you. Or purchase a Hand Vacuum pump and start at the right rear outer bleeder. As soon as the fluid runs clear at each corner of the car, you are good to go. Never touch the brake pedal until done.
Old Nov 17, 2020 | 09:53 AM
thread baron
Perfect, I appreciate the feedback!
Old Nov 17, 2020 | 12:56 PM
HeadsU.P.'s Avatar
HeadsU.P.
While you are waiting to order parts, go ahead spritz the following with PB Blaster and let them soak for days:
The rubber hose fittings on both ends.
All six bleeder screws.
And all eight caliper mounting bolt heads. (just in case)
The caliper pad pins / cotter pins.
Old Nov 17, 2020 | 05:02 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
All good advice.
... and examine the caliper surfaces immediately around each piston and seal for seepage or corrosion buildup. If you spot any, that caliper needs internal parts work.
Old Nov 17, 2020 | 08:16 PM
Sayfoo's Avatar
Sayfoo
Spongy usually means air in the system.
Can you see any leaks at the calipers, hoses, etc.?
If not, a good bleeding might fix it. Flushing the system while you're at it is a good idea if the fluid is old or dark.
Then, the options are endless.
Remember, whenever you change anything on a 50 yr old car, there is the possibility that you'll break something which could lead to a lot of head aches and $$$.
Anymore, if it ain't broke, I don't fix it.
Old Nov 18, 2020 | 12:05 AM
7T1vette's Avatar
7T1vette
Also buy a good quality 6-point crowfoot hex wrench for the brake line fittings. If you don't soak the heck out of those fittings with PB Blaster [for a few days] and then use a good crowfoot wrench (which will not spread open under heavy torque loads when breaking those fittings free), you will damage your present brake lines and need to replace them, too.
Take your time....do it right....and you will have a successful outcome without 'breaking the bank'.
Old Nov 18, 2020 | 08:54 AM
JavaJolt78's Avatar
JavaJolt78
HeadsU.P.:
Terrific post but will this procedure also work on my stock 78SA????
javajolt78
mk's78
Old Nov 18, 2020 | 09:27 AM
HeadsU.P.'s Avatar
HeadsU.P.
I have no idea.
What my post refers to is basic diagnostics of what parts need to be replaced and which don't. And trying to keep things simple, then see what's lurking later.
Most of those old disc brake rotors are / were very meaty. So no need to replace in most cases until they do not meet specs anymore. If one can avoid replacing rotors, you not only save money, but the extra labor of drilling out rivets and checking for rotor run-out is a blessing. New pads will adapt to old rotors easily.
Supposedly, rubber brake lines life span is 10 yrs. Most of us change them out after 25-30-40 yrs. They have a bad reputation of collapsing internally, unseen by the naked eye. And that in itself is almost as bad as a rupture. So it just makes sense to swap them out, safety & hardship. And its cheap at $40 a set.
New pads, hoses. Hopefully the MC is ok, as well as the Proportioning Valve. Calipers are always questionable on C3s, but this is a good start for the O.P.
Also, by soaking everything down with PB Blaster in advance, you are less likely to start breaking fittings at the hose ends. If a bleeder screw snaps off, . . . .well . . . . . you know . . . . Mo $$$
Old Nov 18, 2020 | 10:08 AM
barkingrats
Originally Posted by JavaJolt78
HeadsU.P.:
The disc brake system and components on Corvettes are just about identical from '65 to '82 with a few exceptions. For the most part your '78 is the same as my '72; the process and things to look out for are the same.
Old Nov 18, 2020 | 10:33 AM
JavaJolt78's Avatar
JavaJolt78
Tx for reaching out
JJ78
To Brake Options
