Need help
Old Nov 26, 2020 | 12:15 AM
Joshua Ruiz's Avatar
Joshua Ruiz
Default Need help
Hello I have a 1976 corvette and it has the 350 and I’m having problems with the engine staying alive. At first the carburetor (quadrajet) wasn’t working and wasn’t delivering gas so we had to pour it in so we replaced it and the new quadrajet works great but the car doesn’t want to stay alive unless you are Reving the engine which I’m not sure why it dies if you don’t after a couple of seconds? Any fix to this?
Old Nov 26, 2020 | 12:31 AM
VF-301's Avatar
VF-301
2024 C1 of the Year Finalist - Modified
Fuel pump & filters ! Gas goes bad in a hurry nowadays also.
Old Nov 26, 2020 | 04:02 AM
Lachymac1's Avatar
Lachymac1
Here's a couple of papers by Lars who knows a lot about Quadrajets.
http://corvette-restoration.com/wp-c...arb_Tuning.pdf
http://corvette-restoration.com/wp-c...leshooting.pdf
Assuming your fuel pump is delivering fuel to the carb. Double check your timing and check for any vacuum leaks then have a good read of the above papers.
Was the new quadrajet a rebuilt carb? Is it only like this on cold starts? What type of choke?
A video may help too!
Old Nov 26, 2020 | 01:30 PM
Joshua Ruiz
the new quadrajet was a remanufactured one and the choke I think it said it was hot air and I’m not sure as it doesn’t stay on long enough for me to go on a drive
Old Nov 26, 2020 | 01:36 PM
lars's Avatar
lars
Your problem is that you bought a commercially rebuilt carb. It is complete junk, and likely has an inoperative idle circuit, amongst many other problems. Use it as a door stop and find a good, used, original, rebuildable carb. Hopefully, you kept the original carb off your engine and didn't trade it in on the junk carb - that would have been a very bad idea. It's highly unlikely that you will be able to do anything to the junk carb you bought to make it run right - I typically throw them in the trash can since there are usually no usable or salvageable parts on those carbs. If you'd like a list of all the issues you have going on with that carb, send me an e-mail request for my "Commercially Rebuilt Q-Jet Problems" paper.
Lars
V8FastCars@msn.com
Old Oct 18, 2021 | 04:30 AM
Budryzer's Avatar
Budryzer
My 2 cents is 100% timing. I know exactly what the Whoomp sound is and its that the timing is off. You will have to do as mentioned above with setting the #1 piston at top dead center, aligning the balancer to 0 degrees on the pointer and reinstalling the distributor with the rotor pointing to the #1 plug position. Good luck
Old Oct 18, 2021 | 01:53 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
uh,umm, ok.
have you turned the idle screw?
checked timing?
can you use your foot to get any idle that stays running at any static rpm?
Old Oct 18, 2021 | 10:40 PM
Giddy-up Go's Avatar
Giddy-up Go
you may have garbage in the fuel tank- corrosion and meta; rust flakes that clog the fuel
Old Oct 19, 2021 | 08:13 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Where did you get your replacement carb?
Jebby
Old Oct 19, 2021 | 12:09 PM
Hopper12's Avatar
Hopper12
Just an fyi, this thread is approaching 1 yr old with no updates from the OP. I've done that before too.
Old Oct 19, 2021 | 12:41 PM
Gold Dragon's Avatar
Gold Dragon
Year old thread or not, always a good idea to check the vacuum hoses. The op is probably stranded somewhere and needs a tow.
Old Oct 19, 2021 | 01:07 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
To Need help
