78 corvette clock
Old Dec 27, 2020 | 02:10 PM
609Frankm's Avatar
609Frankm
Default 78 corvette clock
just put in new temp gauge i already change clock and circut board clock was working fine after i change temp gauge the clock seconds hand just goes back and forth now any ideas
Old Dec 27, 2020 | 08:38 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
did you put in a quartz clock convertion?? could the second hand just be loose on the shaft? are the hour and minute hands working?
if none of the hands are turning, perhaps you need a new quartz clock convertion.
Old Dec 27, 2020 | 08:47 PM
609Frankm's Avatar
609Frankm
Default Clock
no I did not put a new conversion in the hands work manual but will try the conversion first thanks will update
Old Dec 27, 2020 | 09:54 PM
4-vettes's Avatar
4-vettes
worth it in the long run. Very affordable, I put in the quartz clock convertion back in the mid 90's. clock still keeps perfect time. You can get them from all the Corvette vendors.
To 78 corvette clock
