Worthwhile upgrades for my 73
If anything, I may use composite spring, Bilstein shocks, and maybe adjustable heim joint rear struts. But, maybe not???
My suggestions would be:
Willwood brake caliper upgrade, they never leak,
Borgeson steering box, replaces the oem box, slave cylinder and hoses that constantly leak,
17” wheels and tires for better handling and ride,
Monoleaf composite rear spring and new coils up front with new sport shocks all around,
New Moog rubber bushings or good quality Energy Suspension poly bushings or a combination of both,
Send your carb to Lars (forum member and carb/timing guru), have him rebuild your oem Qjet and set up timing pursuant to his timing papers,
New wiring harness, American Auto Wire or Letriclimited both have complete oem and restomod harnesses available,
Headers, long tube,
Performance intake manifold, drop base air cleaner, to ensure hood clearance,
HEI, MSD or other preferred ignition system,
DeWitts aluminum radiator with dual electric fans,
New or rebuilt seatbelts,
Etc...
If you are going through the engine there is a multitude of performance upgrades that will quickly break the bank like,
aluminum heads, roller camshafts, pistons, rods, strokes kits and the list goes on and on!
Another costly but one of the most recommended upgrades, especially if you are planning to really drive the car would be to go to an overdrive transmission, either five speed manual or overdrive automatic.
Thats a short list and not intended in any order.
I’ll be starting my 73 restomod project soon.
We do like pictures, can you post some of you project and keep us updated on your progress?
My C3 pet peeve is owners that compromise the car by focusing on audio system replacement and performance. Bottom line in my experience is that the C3 is not the natural habitat for listening to anything except V8 engine noises. Drive the Honda if you want to listen to music or talk on the phone.
Ken
1 - Replace the stock rear spring with a fiberglass spring. You'll need to replace the shocks also to eliminate a 'bouncy' rear end.
2 - Add a sound deadening material under the carpet.
There are many posts related to both these changes. The spring change makes the ride smoother while the other quiets the car and eliminates a lot of heat inside.
