Smog timing
Old Jan 18, 2021 | 06:57 PM
Joshua Ruiz's Avatar
Joshua Ruiz
Default Smog timing
Hello I have a 1976 corvette with the 350 engine and was wondering if anyone knew what degrees it’s supposed to be at when it’s idling and when it’s at 2500 rpm I’m not sure if what I have is correct and I need it to be timed for smog (it’s a federal emissions car) I don’t have the stickers on it so I’m not sure what it’s supposed to be at
Old Jan 18, 2021 | 07:47 PM
MelWff's Avatar
MelWff
With vacuum to distributor disconnected, 6 degrees BTDC. There is no timing spec adjusrment at 2,500 for stock engine.
Old Jan 19, 2021 | 05:15 PM
MelWff's Avatar
MelWff
You had another thread back in December and also never responded to it and you were told what to set the timing to
https://www.corvetteforum.com/forums...st-failed.html
same in November
https://www.corvetteforum.com/forums...smog-ca-2.html
Old Jan 19, 2021 | 07:15 PM
62corvette's Avatar
62corvette
same in November
Good catch, Mel! I just love it when we try to help someone who is playing games. Thanks for outing him.
To Smog timing
