Wiring mystery
Old Jan 24, 2021 | 06:54 PM
mich2112's Avatar
mich2112
5th Gear
Default Wiring mystery
Trying to figure out why this was done and what wires these control. I have been reviewing several diagrams including one from Wilcox and its just not clear. I requested some other copied from member "papawana". If anyone has any ideas I would approciate it.
Thanks, Mike Jones
Old Jan 24, 2021 | 09:10 PM
caskiguy's Avatar
caskiguy
Sorry I screwed this up I uploaded the wrong information.....my bad. But it may come handy. lol.
I'll see if I can find the right engine electrical guide
Old Jan 24, 2021 | 09:30 PM
interpon's Avatar
interpon
I don’t have those 2 sticking out..clean the off and try to see how in harness..
i see you say 78 in your profile
Old Jan 24, 2021 | 09:36 PM
Greg's Avatar
Greg
Just another Corvette guy
Only a guess here Mike, but maybe this plug went bad and a previous owner hard wired that connection.
I agree with interpon, remove the tape and see what's there.
Cheers, Greg
Old Jan 24, 2021 | 09:41 PM
mich2112's Avatar
mich2112
5th Gear
Default Wiring
It’s a 1978 L82 silver anniversary automatic with ac, pw. I haven’t powered it up yet so I don’t know if it has power door locks.
Old Jan 24, 2021 | 09:46 PM
mich2112's Avatar
mich2112
5th Gear
it is coming out of the harness that travels down and appears to go to the starter.
any idea what that “shoot off” of the harness powers?
but yes I guess I will have to do some forensics. Can that connector be had if I want to put it back to original?
Old Jan 24, 2021 | 10:02 PM
caskiguy's Avatar
caskiguy
https://docs.google.com/viewer?a=v&p...2IwMmEzZDkyY2M
https://sites.google.com/a/c3vrmail....iring-diagrams
These may help
Old Jan 25, 2021 | 12:37 AM
bmotojoe's Avatar
bmotojoe
Those 2 pig tailed wires from the 4 wire black housing starter harness connector should be Black And Red.
There should be a 2 wire black plastic connector housing inside that taped up bundle.
From the pig tailed connector from the starter harness there should also be a 2 wire connector in the AC harness. Those 2 connectors connect together and feeds HI Speed Blower Relay and blower motor ground.
Willcox Corvette Link (Connector Center Page Named Starter Motor Jumper Harn):http://repairs.willcoxcorvette.com/1...tic-ac-heater/
My 77 starter and AC harness is very similar.
Links to both harnesses,
Starter Harness:https://www.lectriclimited.com/start...harness-102810
AC Harness:https://www.lectriclimited.com/air-c...harness-118687
(notice the 2 wire connector just after the firewall rubber grommet, that connector plugs into the pigtail connector from the starter harness)
Old Jan 25, 2021 | 02:41 AM
7T1vette's Avatar
7T1vette
Disconnect the battery before you mess with ANY wiring.
Old Jan 25, 2021 | 07:45 AM
bmotojoe's Avatar
bmotojoe
True, Good advice
Old Jan 25, 2021 | 10:22 AM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
This should be a given, but worth repeating!
Old Jan 25, 2021 | 08:51 PM
mich2112's Avatar
mich2112
5th Gear
Default Mystery solved - thanks
Thanks for all the help. Now I know it’s the power for the ac harness and I even have a good idea of the connector that is required from the Wilcox ac diagram. I need to take all the tape off and see what is hiding underneath...I’m betting it’s two wire nuts unfortunately.
Old Jan 25, 2021 | 10:16 PM
bmotojoe's Avatar
bmotojoe
Here are the correct GM Part numbers for the housings & crimp connectors.
(1) Male Black Plastic 2 Wire Housing GM #2984883
(1) F/M Black Plastic 2 Wire Housing GM #2973781
(1) #12 Male Crimp Connector GM #2971859
(1) #12 F/M Crimp Connector GM #2989877
(1) #16-#14 Male Crimp Connector GM #2971962
(1) #16-#14 F/M Crimp Connector GM #2965867
Here is a complete set of the correct Housings And Crimp Connectors LINK: https://www.ebay.com/itm/GM-2-Termin...UAAOSwjrNdAWzk
If you purchase from the e-bay seller ask to substitute 1 #12 Male & 1 #12 F/M crimp connectors, otherwise all the crimp connectors will be #16-#14 gauge wire. You Need 1 Male & 1 F/M in #12 gauge.
You can also get these from Mouser Electronics LINK:https://www.mouser.com/
On the Mouser Homepage just type in the part numbers from above.
On the crimp connectors most are a minimum order of 20ea.
Hope this helps...
Old Jan 28, 2021 | 11:33 PM
caskiguy's Avatar
caskiguy
To whom it may concern Dr.Rebuild requested the wiring guide I listed removed.
Old Jan 29, 2021 | 08:31 AM
Bikespace's Avatar
Bikespace
Wiring diagrams can also be found here:
http://wordpress.keystonestatecorvet...m/?page_id=118
To Wiring mystery
