air vents
Old Jan 25, 2021 | 08:27 PM
VinniePG's Avatar
VinniePG
Default air vents
Hi, my center air vent fins are busted and I wanted to replace them. I have the replacement parts, but i can not figure out how to remove the old vent. I have the center console out of car. Can anyone explain how to remove them?
Old Jan 25, 2021 | 09:52 PM
bobby70's Avatar
bobby70
WHAT year is it on my 70 it has 3 screws 1/4 in socket the whole plastic housing comes off then replace the old vents
Old Jan 25, 2021 | 10:51 PM
kdf1986's Avatar
kdf1986
I like Bobby70 quick answer for your question. It comes out as a section of the gauge cluster. Along with the wiper switch, and wire disconnect at the back.
kdf
Old Jan 27, 2021 | 05:32 PM
VinniePG's Avatar
VinniePG
Default Air vents
Sorry it is a 1975 Vette. There are 2 center vents in console, no screws. I realized that these were the same as early 70' chevelle. I figured how to get them out, but putting new ones in are a PIA.
Old Jan 27, 2021 | 07:10 PM
aquaroscoe's Avatar
aquaroscoe
I did mine yesterday on a 1970 with AC. For me it took 5 screws and about 45 min. Super simple. The center gauge cluster did not need to come out. The cast metal portion behind the wiper switch is easily removed. Then it is only the 3 1/4" screws mentioned above.
Old Jan 28, 2021 | 12:45 AM
7T1vette's Avatar
7T1vette
The wiper switch housing has 3 screws on the underside that must be removed, too. No need to remove the bezel piece.
To air vents
