View Poll Results: What color do I paint my Big Block?
Black
9
16.36%
Orange
46
83.64%
Voters: 55. You may not vote on this poll
1979 BBC - Black or Orange
Old Feb 10, 2021 | 09:22 PM
ChrisLSx's Avatar
ChrisLSx
Default 1979 BBC - Black or Orange
I'm swapping my 1979 to a BB (gen 6) and I'm trying to decide what color to paint the engine, black or orange.
I know 1979 never came with a BB and everything by 79 was black, but hey, it's a resto-mod so I can do whatever I want. I'm thinking black but I'd love some other input.
Old Feb 11, 2021 | 07:30 AM
derekderek's Avatar
derekderek
you are kicking it old-school. orange.
Old Feb 11, 2021 | 09:07 AM
gbvette62's Avatar
gbvette62
In 79, the engines were painted GM Corporate Blue, they didn't start painting engines black until late 82. The blue was used from about January 77, until about July 82.
Personally I've always liked the Chevrolet Engine Orange most, but if you're trying to give your big block conversion a "stock" looking appearance, the blue might be the way to go. I've never been a fan of black engines. The black always makes it harder to find leaks, and makes an already dark engine compartment, look even darker.
SH-60B's Avatar
SH-60B
Blue
Old Feb 11, 2021 | 09:23 AM
stingr69's Avatar
stingr69
Resto mod could go blue or orange either way. You can choose to bring a theme to the build with that choice.
Old Feb 11, 2021 | 10:33 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
What color is your car's exterior? That could play a role a in custom installation.
Old Feb 11, 2021 | 10:41 AM
ChrisLSx's Avatar
ChrisLSx
Silver exterior. The interior is going to be black.
Old Feb 11, 2021 | 11:21 AM
SteveG75's Avatar
SteveG75
Honestly, unless you are going to paint the heads and manifold, you will not see much of the block at all. C3 engine compartment is tight with the big block.
I would not do black just for leaks, etc. I did orange to be traditional. I also considered orange valve covers, but I got a good deal on these Ansen powedrcoated black. Most of what you see on my engine is unpainted aluminum (heads, manifold, water pump).
Old Feb 11, 2021 | 11:46 AM
derekderek's Avatar
derekderek
you can clearly see the 1/2 inch wide strip behind the timing cover...
Old Feb 11, 2021 | 11:48 AM
ChrisLSx's Avatar
ChrisLSx
For now, it will be iron heads (so painted) but the intake is going to stay bare aluminum and eventually I'll put aluminum heads on as well.
Old Feb 11, 2021 | 11:57 AM
walleyfisher's Avatar
walleyfisher
If it as mine, I would not use any standard engine color. I would use some accent car color that goes with the silver you car is painted say .. metallic grey, deep blue, yellow, purple something like that
Old Feb 11, 2021 | 12:07 PM
ChrisLSx's Avatar
ChrisLSx
That's a cool idea, I hadn't thought in those terms. I'll give that a look.
Old Feb 11, 2021 | 12:23 PM
Hopper12's Avatar
Hopper12
^^^^ I like this idea. I've used catalyzed enamel on engines before and it holds up remarkably well if the bare metal is prepped correctly (holds up much better than the rattle can engine enamels - which aren't all that bad). This opens up a whole new set of options - from an exact match to your car, complimentary, contrast, etc. You might consider your caliper color at the same time? BTW, I like the way you're thinking!
Old Feb 11, 2021 | 12:31 PM
SteveG75's Avatar
SteveG75
Yeah, it is a little dirty. LOL. 20K+ miles in 8 years. 2020 was the first year I did less than 2k.
Old Feb 11, 2021 | 12:43 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The 79' Chevy truck had a 454 painted corporate blue....just FYI.....
For me....its gotta be orange.
Jebby
Old Feb 11, 2021 | 09:23 PM
zmanabba's Avatar
zmanabba
I agree with all who mentioned that black makes it harder to work on. I painted the 454 that I swapped into my 77 K10 black (don't remember my reason ) and it seems like the Black color sucks all of the light out of the engine compartment. Harder to see details leaks, missing fasteners etc...
Old Feb 12, 2021 | 02:37 AM
OldCarBum's Avatar
OldCarBum
Silver block, heads and intake, set off by black accessories and brackets.
Throw on a few well planned chromed or polished aluminum pieces and it will pop when you open the hood.
To 1979 BBC - Black or Orange
Old Feb 12, 2021 | 09:27 AM
The Grinch's Avatar
The Grinch
I vote for Detroit diesel alpine green!!
or rocket 88 dark green.
I have painted my engines red, orange, corporate blue, Detroit green, and Cummins tan in recent years. I am not a fan of black.
my current 350 in the 80 c3 is cummins tan. Car is red and inside is doe skin. I went with the tan to contrast the red, match the doe skin , be easy to spot leaks, and be different. Looks good with flat black accents.
here is my formula for painting engine blocks...
clean and degrease.
scuff with sand paper and wire wheels
soak down with POR 15 Marieke clean for an acid key and rust nutrilizer
2 coats of POR 15 Aluminum color. You could leave it in this as it looks real cool. I let this soak in and it self levels amazing.
when second coat of the por is tacky I shoot a color coat and then top coat with color as it flashes.
gives a great long lasting finish. And can be done in freaking temps ...
I too coat with the engine spray paint because it makes touch up easer later if I need too.
corp blue on these valve covers and just the por on the intake
Old Feb 12, 2021 | 04:52 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
The orange looks real good especially with aluminum.
Old Feb 12, 2021 | 06:05 PM
C3 4ME's Avatar
C3 4ME
I own a black 79, and my engine was black when I got the car. It's the original small block that someone painted black somewhere along the way. I painted it the incorrect chevy orange, as opposed to the correct corporate blue, because to me all small blocks and in your case big blocks should be chevy orange, so you should be able to guess what my vote was.
